Home » Language IDEs » Java Development Tools (JDT) » sharing java projects among 3.3 and 3.4 workspaces
sharing java projects among 3.3 and 3.4 workspaces [message #256361] Sat, 13 September 2008 08:39 Go to next message
will sharing a java project (via svn) between 3.3 and 3.4 workspaces
cause problems?
Felix
Re: sharing java projects among 3.3 and 3.4 workspaces [message #256367 is a reply to message #256361] Sun, 14 September 2008 10:20 Go to previous messageGo to next message
Felix Dorner wrote:
> cause problems?
Yes. Moving forward is supported i.e. you can start a 3.3 workspace with
3.4 but if you start a 3.4 workspace with 3.3 unexpected things can
happen and hence that scenario is not supported.
Dani
> Felix
Re: sharing java projects among 3.3 and 3.4 workspaces [message #256374 is a reply to message #256367] Mon, 15 September 2008 01:02 Go to previous messageGo to next message
"Daniel Megert" <daniel_megert@ch.ibm.com> wrote in message
news:gaj6ih$tq0$1@build.eclipse.org...
> Felix Dorner wrote:
>> cause problems?
> 3.4 but if you start a 3.4 workspace with 3.3 unexpected things can happen
You can probably get away with it, depending on what features you use - it's
not _supported_, as Dani said, but that doesn't mean it won't work. You
might want to back up your workspace and then give it a try and see what
happens.
Re: sharing java projects among 3.3 and 3.4 workspaces [message #256377 is a reply to message #256374] Mon, 15 September 2008 03:40 Go to previous messageGo to next message
>> Felix Dorner wrote:
>>> Hi,
>>> cause problems?
Well, it's not just "not supported": there are many things that change
or are new with a new release. You will get exceptions e.g. if you have
a new view open and then start with an older version and you might loose
all the settings made in that view. Now, sure, if you only use the
simplest features it might work.
If you really have to start with an older version (e.g. because a
plug-in doesn't run anymore on 3.4 - which shouldn't happen) from time
to time, why not use a different workspace and share the code via
repository?
Dani
> You
> happens.
Re: sharing java projects among 3.3 and 3.4 workspaces [message #256386 is a reply to message #256361] Mon, 15 September 2008 08:32 Go to previous messageGo to next message
Felix Dorner wrote:
> cause problems?
I've been doing it on a daily basis since at least 3.4M5 (maybe even
earlier). It works pretty flawlessly other than a few small specific
things that I am careful NOT to check in. In my situation, I'm the only
team member using 3.4 and our we are building plugins/features and an
RCP product. For example, the launch shared configuration files get
touched by 3.4 in a way that caused them not to work in 3.3, so I just
make sure not to check them in. I don't remember the details, but there
were a couple of other small differences (in stuff like the .product or
..target file contents, I don't remember exactly) that I have to also
ignore (not check in).
Hope this helps,
Eric
Re: sharing java projects among 3.3 and 3.4 workspaces [message #256412 is a reply to message #256377] Mon, 15 September 2008 16:02 Go to previous messageGo to next message
Hi Daniel,
maybe I was misunderstood. What I am sharing in my repositories are java
projects, not entire workspaces. Each client has its own (version
specific) workspace. Still there is some metadata inside a project:
- the custom builders
- the .classpath and .project files
The question is whether these files are properly interpreted by 3.3 and
3.4 clients
Felix
> repository?
Re: sharing java projects among 3.3 and 3.4 workspaces [message #256425 is a reply to message #256412] Tue, 16 September 2008 03:26 Go to previous message
Felix Dorner wrote:
> Hi Daniel,
> java projects, not entire workspaces. Each client has its own (version
> and 3.4 clients
If you only store 3.3 based project meta data then this will work. Only
when you start storing project settings that appeared in 3.4 you might
get into trouble (e.g. loose them again when committed to CVS via 3.3
workspace).
Dani
> Felix
>> time to time, why not use a different workspace and share the code
>> via repository?
Previous Topic:SearchEngine not finding expected results
Next Topic:Interaction of folding and offsets used by JDOM and AST
Current Time: Tue Jul 22 02:42:21 EDT 2025
Powered by FUDForum. Page generated in 0.06280 seconds
