| Exception handling AspectJ [message #25287] |
Tue, 26 August 2003 03:47 |
Originally posted by: kobi_willy.yahoo.de
i just got a problem while i was trying to implement AspectJ Exception
handling. I have the following code that shall intercept the normal
try-catch implementation.
pointcut changePriceExc(): handler(NegativePriceException);
void around(): changePriceExc()
System.out.println("ASPECT: Exception Handler");
I am getting the Compiler Error:
"Only before advice is supported on handler join points"
My question now is, if there s a compiler version, that still allows this
kind of handler interception, or if anyone has a workaround to intercept
handlers in the way i want to in the code above?
I only had the idea to delete the catch construct in the application code
and work with the before advice. But thats not really acceptable.
Thanks so far
FUDForum. Page generated in 0.24979 seconds
