Home » Archived » BIRT » PDF report using XML data source - hangs (or so it seems)
PDF report using XML data source - hangs (or so it seems) [message #256047] Mon, 24 September 2007 12:45
Originally posted by: craftsman.programmer.gmail.com
I have a report that hangs (or so it seems - I never get to see the
report) when it's fed a relatively large XML data source - with a smaller
data source everything works fine (though a bit slow). This happens both
in the designer in preview mode and when running inside a web application.
I would be glad to post both the report design and the XML but I don't
know how to do it in this newsgroup.
Thank you for your attention,
Johnny
Previous Topic:Deprecated API in BIRT 2.2
Next Topic:"BIRT Report Viewer" text in report and title bar
Current Time: Fri Oct 31 16:50:53 EDT 2025
Powered by FUDForum. Page generated in 0.03272 seconds
