Home » Archived » BIRT » IScriptedDataSetEventHandler and classpath
IScriptedDataSetEventHandler and classpath [message #255906] Fri, 21 September 2007 05:55 Go to next message
Is there a way of making an IScriptedDataSetEventHandler implementation
class visible to BIRT from a different plug-in. I have an RCP application
which has a scripted data set event handler which I need to make available
to the BIRT report designer in preview mode.
I have tried exporting the package with the relevant class in my plug-in but
when attempting to preview the report I get:
Error.ScriptClassNotFoundError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Class
com.test.ui.rpt.birt.ReportDataSetListener not found
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.getInstance(ScriptExecutor.java:107)
Jos
Re: IScriptedDataSetEventHandler and classpath [message #255919 is a reply to message #255906] Fri, 21 September 2007 12:18 Go to previous messageGo to next message
Jose,
Take a look at this article
http://www.eclipsezone.com/articles/eclipse-vms/
Here is a message that Darek posted on this NG.
This article DID HELPED A LOT!!!
I don't know if this is a "proper" solution, but when I added a:
Eclipse-BuddyPolicy: registered
to /META-INF/MANIFEST.MF in org.eclipse.birt.report.engine_x.y.z.jar and
then:
Eclipse-RegisterBuddy: org.eclipse.birt.report.engine
to my plug-ins manifest it worked!!! No more ClassNotFoundException at
all!!! Without even setting anything by System.setProperty(*, *);
Jason
Jose Hernandez wrote:
> at
> Regards
> José
Re: IScriptedDataSetEventHandler and classpath [message #255990 is a reply to message #255919] Mon, 24 September 2007 02:24 Go to previous messageGo to next message
Originally posted by: firstname.lastname.napa.fi
On Fri, 21 Sep 2007 19:18:41 +0300, Jason Weathersby =
<jasonweathersby@alltel.net> wrote:
> to /META-INF/MANIFEST.MF in org.eclipse.birt.report.engine_x.y.z.jar a=
nd
I did the same to org.eclipse.birt.report.viewer, but that was to mak=
e =
javasript able to access classes inside the drivers.
Wouldn't it be a good idea to have "Eclipse-BuddyPolicy: registered" =
in =
these two plugins? Then it would not be necessary to tweak birt =
installation to get classloading working properly.
I have already requested this for org.eclipse.birt.report.viewer in t=
his =
bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D202049
It might also be a good idea to have a page about classloading issues=
and solutions in the faq/wiki/wherever - these seem to come up in the =
newsgroup a lot.
-Antti-
Re: IScriptedDataSetEventHandler and classpath [message #256021 is a reply to message #255990] Mon, 24 September 2007 11:59 Go to previous messageGo to next message
Antti,
good points.
Jason
> I did the same to org.eclipse.birt.report.viewer, but that was to make
> in these two plugins? Then it would not be necessary to tweak birt
> this bug report:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=202049
> newsgroup a lot.
> -Antti-
Re: IScriptedDataSetEventHandler and classpath [message #256175 is a reply to message #256021] Tue, 25 September 2007 16:19 Go to previous message
I was hoping for a solution that did not involve modifying the BIRT
installation but the workaround you have provided is simple and really
useful nevertheless.
Thank you both for your replies.
Jose
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:fd8mos$q3j$1@build.eclipse.org...
> Antti,
> good points.
> Jason
>> Wouldn't it be a good idea to have "Eclipse-BuddyPolicy: registered" in
>> this bug report:
>> newsgroup a lot.
>> -Antti-
Previous Topic:[2.2 RC0] Change value of header after page break
Next Topic:expand and collapse
Current Time: Tue Jul 22 00:41:53 EDT 2025
Powered by FUDForum. Page generated in 0.30018 seconds
