Home » Archived » BIRT » "BIRT Report Viewer" text in report and title bar
"BIRT Report Viewer" text in report and title bar [message #255837] Wed, 19 September 2007 10:12 Go to next message
Originally posted by: spaddock.rogers.com
In version 2.1 I had asked how to take the "BIRT Report Viewer" text out
of the report viewer screen.
I was directed to the FramesetFragment.jsp page and could modify that
quite easily.
In version 2.2 it seems that value is set somewhere else and I wasn't able
to find it. Where is that value set now and can it still be modified?
Also where is the value set that puts the text "BIRT Report Viewer" in a
popup title bar?
Kindest regards,
Shayne
Re: "BIRT Report Viewer" text in report and title bar [message #255841 is a reply to message #255837] Wed, 19 September 2007 10:37 Go to previous messageGo to next message
I have modified it in the
org.eclipse.birt.report.viewer.ViewerPlugin.properties file.
Snjeza
> quite easily.
> able to find it. Where is that value set now and can it still be
> modified? Also where is the value set that puts the text "BIRT Report
> Viewer" in a popup title bar?
> Kindest regards,
> Shayne
Re: "BIRT Report Viewer" text in report and title bar [message #255844 is a reply to message #255841] Wed, 19 September 2007 11:35 Go to previous messageGo to next message
Where does that file exist for the sample web app?
I see it in a viewer.jar file under my eclipse plugins but not in the
webapp directories. Also in the eclipse directory the property is set to
"BIRT Web Viewer" but in the webapp is says "BIRT Report Viewer".
Kindest regards,
Shayne
Re: "BIRT Report Viewer" text in report and title bar [message #255854 is a reply to message #255844] Wed, 19 September 2007 18:17 Go to previous messageGo to next message
It is in the viewer.jar file.
Snjeza
> to "BIRT Web Viewer" but in the webapp is says "BIRT Report Viewer".
> Kindest regards,
> Shayne
Re: "BIRT Report Viewer" text in report and title bar [message #255876 is a reply to message #255854] Thu, 20 September 2007 14:29 Go to previous messageGo to next message
I see a viewer.jar file in my eclipse plugins but I do not see it anywhere
under the BIRT VIEWER sample webapp. How do I change that text under the
sample web app?
I see a viewer.properties file inside the WEB-INF directory, I tried
adding the viewer.browserTitle property to it but to no avail.
Any help would be greatly appreciated.
Kindest regards,
Shayne
Re: "BIRT Report Viewer" text in report and title bar [message #256056 is a reply to message #255876] Mon, 24 September 2007 13:09 Go to previous message
I found it. It's inside the viewservlets.jar
I extracted the jar and modified the
org.eclipse.birt.report.resource.Messages.properties file. Changing the
birt.viewer.title property.
-Shayne
Previous Topic:PDF report using XML data source - hangs (or so it seems)
Next Topic:Changing Cell/DataItem CSS through Script
Current Time: Wed Nov 05 04:24:13 EST 2025
Powered by FUDForum. Page generated in 0.04415 seconds
