Home » Eclipse Projects » Eclipse Platform » Sharing Eclipse Preferences in a Team
Sharing Eclipse Preferences in a Team [message #255815] Sat, 26 June 2004 06:36 Go to next message
Originally posted by: agent.smith.matrix.com
We have a Eclipse preferences file in the repository. Every developer in the
team uses this preferences file.
This preference file is constantly updated and then every developer checks
it out and imports it so that his Eclipse uses the latest preferences.
Unfortunately this means all-or-nothing. If a developer for example has some
uncritical custom settings like the color of current line highlight, then
his setting is replaced each time he imports the preference file.
Does the preference file for the whole team need to be manually maintained
so that it only contains the settings for the whole team? What do you
recommend?
Re: Sharing Eclipse Preferences in a Team [message #256413 is a reply to message #255815] Mon, 28 June 2004 12:45 Go to previous message
> recommend?
At this point, this is probably the only option using Eclipse alone. You
need to manually prune unwanted entries from an exported preferences file
before sharing it with your team members.
You could look at Bug 36965 and contribute comments there.
cheers,
d.
Previous Topic:Code Formatter Preferences
Next Topic:Access to Classpath Variable in eclipse 3.0 from ANT
Current Time: Thu Jul 17 22:33:10 EDT 2025
Powered by FUDForum. Page generated in 0.04303 seconds
