Home » Eclipse Projects » Eclipse Platform » Fast View not being created?
Fast View not being created? [message #255716] Fri, 25 June 2004 15:19
Recently, I changed my view to be fast-viewed by default by setting
relationship = fast on the view extension element in plugin.xml.
This has caused an error when the perspective is being opened. I think the
problem is that the call to PageLayout.addFastView does not add the view to
the map of views, so an assert fails later when the PageLayout tries to get
the view.
Has anyone successfully used relationship = fast? If so, do I need to do
more than set the element in the plugin.xml?
Or, does anyone know of a workaround so that my view shows up as a fast view
by default?
Martha
Previous Topic:CVS: add a participant to the synchronize manager fails
Next Topic:Eclipse hangs in Fedora Core 2
Current Time: Mon Jun 23 06:39:54 EDT 2025
Powered by FUDForum. Page generated in 0.05319 seconds
