| Java Perspective is blank - cannot get back [message #255449] |
Thu, 24 June 2004 17:37  |
Originally posted by: jasmith.marthastewart.com
Version: 2.1.1
Build id: 200306271545
In my Java Perspective, the Hierarchy window is blank with the message:
"To display the type hierarchy, select a type (for example in the outline
view or in the editor), and select 'Open Type Hierarchy' menu option.
Alternatively, you can drag and drop an element (e.g. project, package,
type) onto this view."
The Outline window is blank with the message:
"An outline is not available."
I don't konw what I did, and I can't seem to recover. Can someone give me
some cluse how to recover?
| Re: Java Perspective is blank - cannot get back [message #255602 is a reply to message #255523] |
Fri, 25 June 2004 09:28  |
Initially no, but even when I go to open a Java file from the File menu
(files last opened), the file will open up, but the Java Perspective pane
is still blank with the error message.
Tom Eicher wrote:
> Do you have a Java file open when these messages appear?
> Jim wrote:
> > I had a handful of projects in my Java Perspective before it went blank.
> > It would take quite some time to recreate these. Is there any way to
> > recover?
> > Jim wrote:
> >>Version: 2.1.1
FUDForum. Page generated in 0.03389 seconds
