Home » Archived » BIRT » Image in cross tab
Image in cross tab [message #255417] Fri, 14 September 2007 02:59 Go to next message
In sample dataset of PRODUCTLINES, I want to use column of PRODUCTLINE and
IMAGE to create a crosstab.
I have created a cube use column of PRODUCTLINE to be dimension and
measure.
Create a cross tab and drop the dimension in row, and measure in detail.
And now I want to design a cross tab like this:
| Car | image(Car) |
| Ship | image(Ship) |
What can I do?
Re: Image in cross tab [message #255514 is a reply to message #255417] Fri, 14 September 2007 13:18 Go to previous message
I do not think you can use image data in the cube, but you can do a
nasty work around by calling a hidden table before the crosstab that
loads a map with the images and then drop an image element into the
crosstab and set its data using its onCreate script. Take a look at the
attached example.
Look at the initialize script and the onCreate script for the row in the
top table. Then look at the onCreate script for both elements in the
cross tab. This is fairly convoluted and there may be a better way of
doing this. You may also want to log a bugzilla entry for this..
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.0.v20070620 Build &lt;2.2.0.v20070626-1003></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<method name="initialize"><![CDATA[importPackage( Packages.java.util );
myimagearray = new HashMap();]]></method>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="7">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">PRODUCTLINE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">TEXTDESCRIPTION</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">HTMLDESCRIPTION</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">IMAGE</property>
<property name="dataType">any</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">PRODUCTLINE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">TEXTDESCRIPTION</property>
</structure>
<structure>
<property name="nativeName">HTMLDESCRIPTION</property>
</structure>
<structure>
<property name="nativeName">IMAGE</property>
<property name="nativeDataType">2004</property>
</structure>
</list-property>
<property name="queryText">select *
from CLASSICMODELS.PRODUCTLINES</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTLINE</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>PRODUCTLINE</design:label>
<design:formattingHints>
<design:displaySize>50</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>TEXTDESCRIPTION</design:name>
<design:position>2</design:position>
<design:precision>4000</design:precision>
<design:usageHints>
<design:label>TEXTDESCRIPTION</design:label>
<design:displaySize>4000</design:displaySize>
<design:attributes>
<design:name>HTMLDESCRIPTION</design:name>
<design:position>3</design:position>
<design:precision>1048576</design:precision>
<design:usageHints>
<design:label>HTMLDESCRIPTION</design:label>
<design:displaySize>1048576</design:displaySize>
<design:attributes>
<design:name>IMAGE</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>2004</design:nativeDataTypeCode >
<design:usageHints>
<design:label>IMAGE</design:label>
<design:displaySize>2097152</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<cubes>
<tabular-cube name="Customer Cube" id="14">
<property name="defaultMeasureGroup">Summary Field</property>
<property name="dimensions">
<tabular-dimension name="Group" id="15">
<property
name="defaultHierarchy">NewTabularHierarchy</property>
<property name="hierarchies">
<tabular-hierarchy name="NewTabularHierarchy"
id="16">
<property name="levels">
<tabular-level name="PRODUCTLINE" id="17">
<property
<property
name="levelType">dynamic</property>
<property
name="columnName">PRODUCTLINE</property>
</tabular-level>
</property>
<property name="dataSet">Data Set</property>
</tabular-hierarchy>
</property>
</tabular-dimension>
</property>
<property name="measureGroups">
<tabular-measure-group name="Summary Field" id="18"/>
</property>
</tabular-cube>
</cubes>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
<style name="NewStyle" id="133">
<property name="display">inline</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="72">
<property name="width">100%</property>
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr">true</expression>
</structure>
</list-property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["PRODUCTLINE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["TEXTDESCRIPTION"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["HTMLDESCRIPTION"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["IMAGE"]</expression>
</structure>
</list-property>
<column id="96"/>
<column id="97"/>
<column id="98"/>
<column id="99"/>
<header>
<row id="73">
<cell id="74">
<label id="75">
<text-property
name="text">PRODUCTLINE</text-property>
</label>
</cell>
<cell id="76">
<label id="77">
<text-property
name="text">TEXTDESCRIPTION</text-property>
</label>
</cell>
<cell id="78">
<label id="79">
<text-property
name="text">HTMLDESCRIPTION</text-property>
</label>
</cell>
<cell id="80">
<label id="81">
<text-property
name="text">IMAGE</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="82">
<method
name="onCreate"><![CDATA[importPackage(Packages.java.io);
importPackage(Packages.java.lang);
xyz = this.getRowData().getColumnValue("IMAGE");
jjj = this.getRowData().getColumnValue("IMAGE").length;
myimagearray.put(this.getRowData().getColumnValue("PRODUCTLINE "),
this.getRowData().getColumnValue("IMAGE"));]]></method>
<cell id="83">
<data id="84">
<property
name="resultSetColumn">PRODUCTLINE</property>
</data>
</cell>
<cell id="85">
<data id="86">
<property
name="resultSetColumn">TEXTDESCRIPTION</property>
</data>
</cell>
<cell id="87">
<data id="88">
<property
name="resultSetColumn">HTMLDESCRIPTION</property>
</data>
</cell>
<cell id="89">
<data id="90">
<property
name="resultSetColumn">IMAGE</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="91">
<cell id="92"/>
<cell id="93"/>
<cell id="94"/>
<cell id="95"/>
</row>
</footer>
</table>
<extended-item extensionName="Crosstab" id="33">
<property name="rows">
<extended-item extensionName="CrosstabView" id="34">
<property name="views">
<extended-item extensionName="DimensionView"
id="35">
<property name="dimension">Group</property>
<extended-item
extensionName="LevelView" name="NewLevel View" id="36">
<property
name="level">Group/PRODUCTLINE</property>
<property name="member">
<extended-item
extensionName="CrosstabCell" id="37">
<property name="content">
<data
name="PRODUCTLINE" id="38">
<property
name="style">NewStyle</property>
<method
name="onCreate"><![CDATA[myproductline = this.getValue();]]></method>
<property
</data>
<image id="71">
<property
<method
name="onCreate"><![CDATA[this.data =
myimagearray.get(myproductline);]]></method>
<property
name="source">expr</property>
<expression
name="valueExpr">row["Column Binding_1"]</expression>
</image>
</property>
</extended-item>
</property>
</extended-item>
</property>
</extended-item>
</property>
</extended-item>
</property>
<property name="cube">Customer Cube</property>
<structure>
<expression
name="expression">dimension["Group"]["PRODUCTLINE"];</expression >
</structure>
<structure>
<property name="name">Column Binding_1</property>
<expression name="expression">"dummy"</expression>
</structure>
</list-property>
</extended-item>
</body>
<list-property name="images">
<structure>
<property name="name">clientprintico.PNG</property>
<property name="data">
iVBORw0KGgoAAAANSUhEUgAAABIAAAAVCAIAAADEqSm4AAAAAXNSR0IArs4c 6QAAAARnQU1BAACxjwv8
YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpR PAAAAd5JREFUOE+tk8sv
A1EUxssfZmFhZSOsBAsbodEISryiXmmxECSIRwgRlaAiXhGPqERppZp2zJQa JtrRalNqOs/S1rmZeiVl
pDH5cpOZe373O+eeOVk226gqgwewDKTKgEEJfsVW9892zOlVVd/+NfIbBkwy mYwnErHYC8dLDCuEI2zw
iaGDkSqt7jcsHk8sb5nnTbsTxo3hGZNh1NgxOEv5wwpY7OWVF2IMK4YjnOwD zLU3pIAB8+62OTRtMowY
OwfncCqggEE9j89c8DGKfO6RD0H5nSStgAHz6TZj6h1bgNrsl3cKWKoe8PGF 3LfIx07cWXHqRwxuv7V/
KnUHvhB+E0CM22vFKAuGMAj46AHqG0HS8KnJMN7SPwlrQ89IQ/dwnW6gpq1P 06yvbuxSa3XQbtiCMAhO
/SXw4glK7oCE0aKTluxe8eSGPyKFgyt+B+c2Xdyag12wMos2Btac/OJP7DIg EQ8Ic/hEGyVaSN7sEfbc
3DbGrjuj1uxsAHKXVGkw3C+5aPHcK57eCsekcOjhdwluC0NWK+dRAGR9c4MM L+5FyF5WrW6oslFfom4u
KNPkFZVDKCgNRvghQwEmQGYqtPpSdUtBWXVeYYqBrTQY3K98pKLkNvzHmP59 0t8A0tcB7BW6gQcAAAAA
SUVORK5CYII=
</property>
</structure>
</list-property>
</report>
> and IMAGE to create a crosstab.
> measure.
> | Car | image(Car) |
> What can I do?
Previous Topic:Birt all in one 2.2.0 installs 1.0.1???
Next Topic:Dynamic table width in PDF format of a report.Is it possible?
Current Time: Sun Aug 31 10:02:36 EDT 2025
Powered by FUDForum. Page generated in 0.03355 seconds
