Home » Newcomers » Newcomers » Auto-resume Java perspective?
Auto-resume Java perspective? [message #255398] Sat, 03 May 2008 10:37 Go to next message
Originally posted by: riwright.adobe.com
> This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
--B_3292645023_58843279
Content-type: text/plain;
charset="ISO-8859-1"
Content-transfer-encoding: 8bit
Eclipse is very nice in the way that starting the debugger takes one to the
debug perspective. Is there any way to tell it that when the debugger is
stopped, go back to the Java (or previous) perspective? I looked in the
preferences under Run/Debug, but it doesn
Re: Auto-resume Java perspective? [message #255406 is a reply to message #255398] Sat, 03 May 2008 10:55 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
If you mean 'can I make Eclipse use the Java (or previous) perspective
to debug instead of the Debug perspective?' then yes:
Window > Preferences > Run/Debug > Perspectives
If however, you want Eclipse to automatically revert to the previous
perspective as soon as you're done debugging... I don't think so.
Perspective changes appear to be controlled by starting a behaviour
(debugging, synching), not ending one.
There's also Window > Preferences > Run/Debug > View Management, which
from the sounds of it can automatically open/close the Debug View in the
Java (or other) perspective as soon as it's needed / no longer needed.
Nick
> the debug perspective. Is there any way to tell it that when the
> debugger is stopped, go back to the Java (or previous) perspective? I
> looked in the preferences under Run/Debug, but it doesn’t seem to allow
> any way to indicate what Eclipse should do when the debugger is stopped.
> TIA, Ric
Re: Auto-resume Java perspective? [message #255414 is a reply to message #255406] Sat, 03 May 2008 13:26 Go to previous messageGo to next message
Yes, what I would like is that when I terminate a debug session it reverts
to the Java perspective. What I find now is that I always have to go click
the "Java perspective" button. Not a big deal and I can even see that it
could be mildly annoying since sometimes you want to terminate a debug
session and simply restart. But not usually (for me, at least). I looked
at the Preferences/Run-Debug stuff. But while it controls entering when/how
to enter a debug session, there is no obvious way to tell it what to do
when debugging stops.
Thanks, Ric
On 5/3/08 7:55 AM, in article fvhued$t4k$1@build.eclipse.org, "Nick Boldt"
> Nick
>> looked in the preferences under Run/Debug, but it doesn¹t seem to allow
>> TIA, Ric
Re: Auto-resume Java perspective? [message #255422 is a reply to message #255414] Sat, 03 May 2008 14:37 Go to previous messageGo to next message
In terms of a quick keyboard-based solution, you could use "CTRL-3, pj"
to switch quickly back to "*P*erspectives > *J*ava".
Note also Shift-Alt-X and Shift-Alt-D for eXecute and Debug (or CTRL-F11
and F11).
Still not what you want, I know. You might want to open an enhancement
bug for Eclipse 3.5.
Nick
> Thanks, Ric
>> Nick
>>> TIA, Ric
Re: Auto-resume Java perspective? [message #255488 is a reply to message #255398] Mon, 05 May 2008 08:51 Go to previous message
> TIA, Ric
There is no such feature or configuration. Implementing one would
require some critical usability questions to be answered. There was a
thread about this a while back:
http://dev.eclipse.org/newslists/news.eclipse.newcomer/msg12 635.html
Hope this helps,
Eric
Previous Topic:cvs history for a branch
Next Topic:Usage of capability pattern
Current Time: Tue Jul 22 00:52:17 EDT 2025
Powered by FUDForum. Page generated in 0.12693 seconds
