Home » Language IDEs » Java Development Tools (JDT) » 3.4 Hot Code Replace Failing
3.4 Hot Code Replace Failing [message #255395] Fri, 01 August 2008 16:47 Go to next message
Originally posted by: bcort.oculusinfo.com
I am finding that Eclipse 3.4 is much less effective at hot code
replacements while debugging than in version 3.3. For example, adding a
comment will cause it to prompt me to terminate/continue.
Are others also experiencing this?
Re: 3.4 Hot Code Replace Failing [message #255401 is a reply to message #255395] Sat, 02 August 2008 00:52 Go to previous messageGo to next message
> Thanks
I've not had any problem with that, personally. If you can come up with
a reliable repro, with details of what JVM etc. you're using, I think
the JDT team would be very interested in a Bugzilla entry. Are you sure
that 3.3 vs 3.4 is the only thing that changed? Is this happening in
plain Java projects, or J2EE, or... ?
Re: 3.4 Hot Code Replace Failing [message #255458 is a reply to message #255401] Tue, 05 August 2008 10:14 Go to previous messageGo to next message
This is happening in plain Java projects. Unfortunately, I can't share the
projects, but will see if I can make a small reproducible test case. I'm
compiling against 1.5.0_15 and running with 1.6.0_06.
"Walter Harley" <eclipse@cafewalter.com> wrote in message
news:g70p5s$1q0$1@build.eclipse.org...
>> Thanks
> I've not had any problem with that, personally. If you can come up with a
> reliable repro, with details of what JVM etc. you're using, I think the
> JDT team would be very interested in a Bugzilla entry. Are you sure that
> 3.3 vs 3.4 is the only thing that changed? Is this happening in plain
Re: 3.4 Hot Code Replace Failing [message #255473 is a reply to message #255401] Thu, 07 August 2008 14:17 Go to previous messageGo to next message
I tried the simplest test case I could and hot code replace works fine.
Is there any way to discover why hot code is failing in my production
projects?
The error log doesn't seem to show anything...
>> Thanks
Re: 3.4 Hot Code Replace Failing [message #255501 is a reply to message #255473] Sun, 10 August 2008 22:09 Go to previous messageGo to next message
When the HCR fails, what exact error message are you getting, i.e. what is
the reason?
Darins
http://www.runnerwhocodes.blogspot.com/
"B C" <bcort@oculusinfo.com> wrote in message
news:g7fe6u$v2f$1@build.eclipse.org...
> projects?
>>> Thanks
>> a reliable repro, with details of what JVM etc. you're using, I think the
Re: 3.4 Hot Code Replace Failing [message #255584 is a reply to message #255501] Wed, 13 August 2008 11:38 Go to previous messageGo to next message
I just tried adding a comment to running code and the reason is "Scheme
change not implemented".
Does this help diagnose?
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:g7o71e$49i$1@build.eclipse.org...
> the reason?
> Darins
>> projects?
>>>> Thanks
Re: 3.4 Hot Code Replace Failing [message #255588 is a reply to message #255584] Wed, 13 August 2008 11:48 Go to previous messageGo to next message
Sorry, that was unclear.
I tried adding a comment to running code and the reason given in the 'Hot
Code Replace Failed' dialog is "Scheme change not implemented".
news:g7uv5i$k43$1@build.eclipse.org...
> Thanks
>> is the reason?
>> Darins
>>> projects?
>>>>> a comment will cause it to prompt me to terminate/continue.
>>>>> Thanks
>>>> with a reliable repro, with details of what JVM etc. you're using, I
>>>> think the JDT team would be very interested in a Bugzilla entry. Are
>>>> you sure that 3.3 vs 3.4 is the only thing that changed? Is this
>>>> happening in plain Java projects, or J2EE, or... ?
Re: 3.4 Hot Code Replace Failing [message #255605 is a reply to message #255588] Wed, 13 August 2008 12:49 Go to previous messageGo to next message
When HCR occurs, the Eclipse debug framework essentially fires off the new
bytes of the changed classfile(s) to the VM.
The VM may or may not accept them. In your case it is rejecting the
change(s).
Scheme change usual means you are adding methods or fields (or making
changes within an innerclass that results in synthetic method changes?).
What VM are you using? Possibly a different VM would
helpDarinshttp://runnerwhocodes.blogspot.com"B C" <bcort@oculusinfo.com>
wrote in message news:g7uvo4$rph$1@build.eclipse.org...
> Thanks
>> Thanks
>>> is the reason?
>>> Darins
>>>> projects?
>>>>>> Thanks
Re: 3.4 Hot Code Replace Failing [message #255608 is a reply to message #255605] Wed, 13 August 2008 13:11 Go to previous messageGo to next message
I'm using Sun's JDK 1.6.0_06.
As I mentioned, this happens for inconsequential changes like adding
comments.
This problem does not happen with Eclipse 3.3 using the same VM.
news:g7v3l1$ejr$1@build.eclipse.org...
> change(s).
>> Thanks
>>> Thanks
>>>> is the reason?
>>>> Darins
>>>>> projects?
>>>>>>> adding a comment will cause it to prompt me to terminate/continue.
>>>>>>> Thanks
Re: 3.4 Hot Code Replace Failing [message #255612 is a reply to message #255608] Wed, 13 August 2008 13:07 Go to previous messageGo to next message
Time for a bug report then with a reproduceable test case.
Sorry I have not helped out
Darins
news:g7v4jg$go7$1@build.eclipse.org...
> comments.
>> new
>> change(s).
>>> 'Hot Code Replace Failed' dialog is "Scheme change not implemented".
>>> Thanks
>>>> Thanks
>>>>> what is the reason?
>>>>> Darins
>>>>>>fine.
>>>>>> projects?
>>>>>>>> Thanks
>>>>>>> Are you sure that 3.3 vs 3.4 is the only thing that changed? Is
>>>>>>> this happening in plain Java projects, or J2EE, or... ?
Re: 3.4 Hot Code Replace Failing [message #256188 is a reply to message #255608] Mon, 08 September 2008 12:08 Go to previous message
I'd just wanted to chip in with a comment here. I stumbled upon this
thread while Googling for any help on a similar issue: I have also noticed
that the hot code replacement have become EXTREMELY picky about what
changes it accepts. Since this isn't based upon hard facts, the bottom
line is that I believe I had much more benefit of the HCR feature before
than after the 3.4 upgrade. (I've run -clean, but not made a new
workspace, to pre-empt comments from a later thread about the same
problem).
What I think often is happening, at least in my case, is that for
non-static inner classes, the hot code replacement fails upon
(user-perceived) minor changes such as accessing or not accessing anymore
a private field/method in the outer class. What's happening here, is that
the compiler has to insert an outer-class accessor method to access it, or
delete these accessor methods if they aren't needed anymore. I actually
believe both insertion and deletion worked earlier, but I am not certain
of the "insert" part. However, that it fails on the deletion is rather
annoying - couldn't it just have let that method be in place until next
restart? I am quite certain that it didn't crash on this specific thing
before.
These issues leads to the annoying fact that if you comment out some code
line in the inner class that includes an access to any private field or
method in the outer class, the HCR stuff fails. And this seems rather
strange, as one seemingly haven't done any "major changes" like overtly
adding fields or methods.
Previous Topic:GregorianCalendar problem
Next Topic:Re: IntelliJ IDEA -> Eclipse feature - Plugin
Current Time: Thu Jul 24 21:13:59 EDT 2025
Powered by FUDForum. Page generated in 0.07767 seconds
