Home » Language IDEs » Java Development Tools (JDT) » Who has successfully build eclipse 3.4 on x86 or other platforms?
Who has successfully build eclipse 3.4 on x86 or other platforms? [message #255381] Fri, 01 August 2008 02:07 Go to next message
Originally posted by: chenal.naritech.cn
I try to build eclipse 3.4 on winxp.
I am using ant1.7.0 and jre1.6.0 as instructed:
1. Add the Ant bin directory to PATH.
2. Set the JAVA_HOME=d:\jdk1.6.0.
3. Set the ANT_HOME=d:\ant1.7.0.
And run the build command
build -os win32 -ws win32 -arch -compilelibs
But the building is failed. Who has successfully build it? Please help
me. Thank you in advance.
Allen
Re: Who has successfully build eclipse 3.4 on x86 or other platforms? [message #255385 is a reply to message #255381] Fri, 01 August 2008 02:15 Go to previous message
Allen Chen wrote:
> Allen
Hi, Allen. I would recommend posting this to the eclipse.platform
newsgroup,
since it has nothing to do with the JDT.
Also, it will help if you can explain what failed, what troubleshooting
steps you
have attempted so far, etc. There are some good hints on how to help people
help you at http://catb.org/%7Eesr/faqs/smart-questions.html .
Previous Topic:how to access info of a removed IJavaElement and how to store an IJavaElement
Next Topic:Restriction on required library
Current Time: Tue Oct 21 06:09:55 EDT 2025
Powered by FUDForum. Page generated in 0.03612 seconds
