Home » Newcomers » Newcomers » cvs update
cvs update [message #255369] Fri, 02 May 2008 13:30 Go to next message
Is there a way to create patches from incoming changes? For example, I
want to review changes done by my coworker at a later date. So I update my
code. But in doing so, I loose track of all changes. When I synchronize
with repository again, there are no changes. I want to be able to save
their incoming changes as a patch, update so that my code is up to date
and then review their patch at a later date.
Is that possible? Maybe there are workarounds. One would be to ask them to
create a patch before submitting which I can use later?
Thanks.
Re: cvs update [message #255373 is a reply to message #255369] Fri, 02 May 2008 13:40 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
1. Switch Synchronize view to Change Sets presentation (that's the view
toolbar button that looks like a folder tree).
2. Select a change set, right-click, and do Open Change in Compare
Editor. Now you can review an entire set of commits for someone on your
team, assuming they're grouped by matching commit comment.
Not sure if this is new in Eclipse 3.4 or requires Mylyn 2.3, but it
works for me here.
Nick
Upkar Lidder wrote:
> Hello,
> my code. But in doing so, I loose track of all changes. When I
> synchronize with repository again, there are no changes. I want to be
> able to save their incoming changes as a patch, update so that my code
> is up to date and then review their patch at a later date.
> to create a patch before submitting which I can use later?
> Thanks.
Re: cvs update [message #255376 is a reply to message #255369] Fri, 02 May 2008 13:51 Go to previous messageGo to next message
Originally posted by: groups.pellaton.li
Hello
Eclipse's CVS client is not that strong in the area of patches/diffs
between arbitrary versions, reverse patches, ...
I use the command line client on unix to create the diffs/patches in
such situations. These patches can then be applied using Eclipse.
HTH
Michael
better workflow for using cvs / reviewing patches (was Re: cvs update) [message #255380 is a reply to message #255369] Fri, 02 May 2008 16:34 Go to previous message
I suppose a revised workflow might help:
a - your colleague(s)
b - you
(a) make patch(es) from the OUTGOING changes before committing them
(a) attach them (and optionally, Mylyn context) to the affected bug(s)
(b) receive notification of the update(s) to the bug(s)
(b) review patch(es) / apply task contexts & apply those deemed worthy.
Or, if you're just reviewing for information to know what's changed
rather than to approve/deny the changes:
(a) commit them
(b) receive notification of the update(s) to the bug(s), and review
Nick
Upkar Lidder wrote:
> Hello,
> Thanks.
Previous Topic:double hints
Next Topic:need arm-linux-gcc
Current Time: Sun Aug 31 18:28:13 EDT 2025
Powered by FUDForum. Page generated in 0.10798 seconds
