Home » Eclipse Projects » Eclipse Platform » Hyperthreading and eclipse
Hyperthreading and eclipse [message #255219] Thu, 24 June 2004 04:04 Go to next message
Originally posted by: naficbm.1net.gr
hello , Intel have released his Hyperthreading cpu,
our plugin become unstabilization in Hyperthreading cup.
I want to know ,
what have eclipse do aim at Hyperthreading .
Re: Hyperthreading and eclipse [message #255234 is a reply to message #255219] Thu, 24 June 2004 05:02 Go to previous messageGo to next message
> I want to know ,
Not sure what is getting "unstable". You need to describe more details.
Actually it doesn't seem to be an Eclipse specific or Java problem at all.
Java supports threading and Eclipse heavily uses this in 3.0 with its
support for background jobs. You should probably check the VM you are using
and review your code for concurrency issues.
Cu, Gunnar
Re: Hyperthreading and eclipse [message #255238 is a reply to message #255234] Thu, 24 June 2004 05:05 Go to previous messageGo to next message
Forgot the most important thing: I'm running 3.0 RC3 on a hyperthreading P4
and there seems to be only one rare issue with sleeping jobs (search
bugzilla for "Decorations become stale"). But in generally it's _pretty_
stable.
Cu, Gunnar
Re: Hyperthreading and eclipse [message #255351 is a reply to message #255234] Thu, 24 June 2004 12:03 Go to previous messageGo to next message
I don't quite get that. IMHO hyperthreading has absolutely nothing to do
with Java thread technology. It's rather a pipelining technology that
simulates a second CPU. I would guess that there actually could be no
issues due to Eclipse code since the default plugins make no assumptions
on the CPU whatsoever. There might be a JVM issue, however that would
have turned up earlier I guess.
Eric - who was using a P4 with hyperthreading on throughout all Eclipse
revisions and never had any problems with that
Eric Bodden
ICQ UIN: 12656220
Website: http://www.bodden.de
GPG: BB465582
Re: Hyperthreading and eclipse [message #255375 is a reply to message #255351] Thu, 24 June 2004 13:32 Go to previous messageGo to next message
Originally posted by: glongman.intelligentworks.nospam.com
I have been using a Hyperthreading CPU for almost a year and have never had
a related problem with any Eclipse build.
Geoff
"Eric Bodden" <newsserver_mails@bodden.de> wrote in message
news:cbetvf$ci5$2@eclipse.org...
all.
using
> Eric Bodden
> ICQ UIN: 12656220
> GPG: BB465582
Re: Hyperthreading and eclipse [message #255491 is a reply to message #255351] Thu, 24 June 2004 19:43 Go to previous messageGo to next message
Originally posted by: john.eclipsefaq.org
We have found that some genuine concurrency bugs just occur more often
when using a hyperthreaded or genuine multi-processor system (such as
referencing a field across multiple threads without a synchronized block
to reconcile them). Any changes to the execution timing of the
application can have this effect. For example, with some concurrency
bugs, introducing println statements for debugging can make the problem
disappear. I agree that a Java program should not have radically
different execution semantics on a hyperthreaded box.
Re: Hyperthreading and eclipse [message #255531 is a reply to message #255351] Fri, 25 June 2004 02:54 Go to previous messageGo to next message
> do with Java thread technology. It's rather a pipelining technology
> that simulates a second CPU. I would guess that there actually could
It's just a general suggestion to review any code because concurrency issus
might occure more often on hyperthreading or multiple processor systems than
on single CPU systems.
Cu, Gunnar
Re: Hyperthreading and eclipse [message #256427 is a reply to message #255219] Mon, 28 June 2004 13:34 Go to previous message
> I want to know ,
We know of problems that seem to be specific to hyper-threading or multi-CPU
machines (likely concurrency problems). Search Bugzilla for bugs
mentioning hyper-threading For example, Bug 63635
(""https://bugs.eclipse.org/bugs/show_bug.cgi?id=63635") deals with
decorator issues and hyper-threading.
cheers,
d.
Previous Topic:Help System crash
Next Topic:How to test a plug-in in R3.0?
Current Time: Tue Nov 04 21:51:12 EST 2025
Powered by FUDForum. Page generated in 0.06462 seconds
