Home » Language IDEs » Java Development Tools (JDT) » ITypeParameter is not an IAnnotatable
ITypeParameter is not an IAnnotatable [message #255197] Wed, 23 July 2008 13:50 Go to next message
I try to use the jdt annotation API, and I stumble as I can't get any
annotations from method parameters.
IField, ILocalVariable, IMethod, IPackageDeclaration, IType are all
IAnnotatable but ITypeParameter is not.
Why is this, better how could I get the annotation from a parameter ?
greetings, urs.
Re: ITypeParameter is not an IAnnotatable [message #255302 is a reply to message #255197] Sat, 26 July 2008 12:26 Go to previous messageGo to next message
"urs zeidler" <ich@urszeidler.de> wrote in message
news:g67r13$6nb$1@build.eclipse.org...
I don't believe ITypeParameter has anything to do with method parameters.
I think ITypeParameter describes type parameters, for instance 'T' in the
following declaration:
class Foo<T> {
T getT() { ... }
void putT(T t) { ... }
And type parameters are not annotatable, in the current definition of Java
(pending JSR-308).
Since IMethod.getParameterTypes returns type signatures rather than IType[],
I am not sure the Java Model will give you information at this level of
detail - I think you may have to use the DOM AST instead, or use APT.
Re: ITypeParameter is not an IAnnotatable [message #255318 is a reply to message #255302] Tue, 29 July 2008 03:34 Go to previous message
You are absolute right.
> (pending JSR-308).
Indeed.
Yes ITypeParameter was the only interface about parameters in the range
of IMethode I found, that's why I mixed it up. And funny is I have
already worked with ITypeParameter in the same UML importer, but in an
other aspect (as template parameter, what they are).
So it looks to me as there is not annotation support on parameter.
That's really pity, I wanted to import the annotation as stereotypes in
an UML model import, now I can't cover parameters.
Perhaps I should open a feature request for it.
thanks for your answer, greetings, urs.
Previous Topic:@override in Interface
Next Topic:IJavaProject instances classloader
Current Time: Sat Jul 26 01:48:28 EDT 2025
Powered by FUDForum. Page generated in 0.11160 seconds
