Home » Newcomers » Newcomers » Plugin classloader error in 3.3 not in 3.2
Plugin classloader error in 3.3 not in 3.2 [message #255081] Wed, 30 April 2008 19:06 Go to next message
Originally posted by: riwright.adobe.com
> This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
--B_3292416377_50934112
Content-type: text/plain;
charset="ISO-8859-1"
Content-transfer-encoding: 8bit
I have a plugin that I created. It
Re: Plugin classloader error in 3.3 not in 3.2 [message #255100 is a reply to message #255081] Wed, 30 April 2008 23:18 Go to previous messageGo to next message
--B_3292431517_51881823
A little spelunking around shows reveals that they have changed the
classloader sequence in 3.3 (
http://help.eclipse.org/stable/index.jsp?topic=/org.eclipse. platform.doc.isv
/porting/3.3/incompatibilities.html) but it isn
Re: Plugin classloader error in 3.3 not in 3.2 [message #255213 is a reply to message #255100] Thu, 01 May 2008 12:08 Go to previous messageGo to next message
Originally posted by: zx.us.ibm.com
Can you be more specific in what you're trying to do?
~ Chris
Re: Plugin classloader error in 3.3 not in 3.2 [message #255390 is a reply to message #255213] Sat, 03 May 2008 09:44 Go to previous messageGo to next message
--B_3292641900_58659948
charset="US-ASCII"
Content-transfer-encoding: 7bit
Chris,
I am simply writing a little view that allows me to show OpenGL demos (using
JOGL and the SWT_AWT bridge). I have attached the plugin xml and manifest
files from the project. I am using the two external jars from JOGL
(jogl.jar and gluegen-rt). Everything else is plain vanilla Eclipse. As
noted, it works fine on several different machines with 3.3. What I'd
really like to know if if there are any diagnostic tools one can use in
Eclipse to sniff out such problems or is the only approach examining the
code?
Ric
On 5/1/08 9:08 AM, in article fvcpta$13g$1@build.eclipse.org, "Chris
> Cheers,
> ~ Chris
Content-type: application/octet-stream; name="plugin.xml"
Content-disposition: attachment;
filename="plugin.xml"
Content-transfer-encoding: base64
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4NPD9lY2xp cHNlIHZlcnNp
b249IjMuMyI/Pg08cGx1Z2luPg0NICAgPGV4dGVuc2lvbg0gICAgICAgICBw b2ludD0ib3Jn
LmVjbGlwc2UudWkudmlld3MiPg0gICAgICA8Y2F0ZWdvcnkNICAgICAgICAg ICAgbmFtZT0i
T3BlbkdMIENhdGVnb3J5Ig0gICAgICAgICAgICBpZD0iY29tLmdlb2Z4Lm9w ZW5nbC52aWV3
Ij4NICAgICAgPC9jYXRlZ29yeT4NICAgICAgPHZpZXcNICAgICAgICAgICAg bmFtZT0iT3Bl
bkdMIFZpZXciDSAgICAgICAgICAgIGljb249Imljb25zL3NhbXBsZS5naWYi DSAgICAgICAg
ICAgIGNhdGVnb3J5PSJjb20uZ2VvZngub3BlbmdsLnZpZXciDSAgICAgICAg ICAgIGNsYXNz
PSJjb20uZ2VvZngub3BlbmdsLnZpZXcuT3BlbkdMVmlldyINICAgICAgICAg ICAgaWQ9ImNv
bS5nZW9meC5vcGVuZ2wudmlldy5PcGVuR0xWaWV3Ij4NICAgICAgPC92aWV3 Pg0gICA8L2V4
dGVuc2lvbj4NICAgPGV4dGVuc2lvbg0gICAgICAgICBwb2ludD0ib3JnLmVj bGlwc2UudWku
cGVyc3BlY3RpdmVFeHRlbnNpb25zIj4NICAgICAgPHBlcnNwZWN0aXZlRXh0 ZW5zaW9uDSAg
ICAgICAgICAgIHRhcmdldElEPSJvcmcuZWNsaXBzZS51aS5yZXNvdXJjZVBl cnNwZWN0aXZl
Ij4NICAgICAgICAgPHZpZXcNICAgICAgICAgICAgICAgcmF0aW89IjAuNSIN ICAgICAgICAg
ICAgICAgcmVsYXRpdmU9Im9yZy5lY2xpcHNlLnVpLnZpZXdzLlRhc2tMaXN0 Ig0gICAgICAg
ICAgICAgICByZWxhdGlvbnNoaXA9InJpZ2h0Ig0gICAgICAgICAgICAgICBp ZD0iY29tLmdl
b2Z4Lm9wZW5nbC52aWV3Lk9wZW5HTFZpZXciPg0gICAgICAgICA8L3ZpZXc+ DSAgICAgIDwv
cGVyc3BlY3RpdmVFeHRlbnNpb24+DSAgIDwvZXh0ZW5zaW9uPg0gICA8ZXh0 ZW5zaW9uDSAg
ICAgICAgIHBvaW50PSJvcmcuZWNsaXBzZS51aS5hY3Rpb25TZXRzIj4NICAg ICAgPGFjdGlv
blNldA0gICAgICAgICAgICBpZD0iY29tLmdlb2Z4Lm9wZW5nbC52aWV3LmFj dGlvblNldCIN
ICAgICAgICAgICAgbGFiZWw9IlNlbGVjdCBTY2VuZSINICAgICAgICAgICAg dmlzaWJsZT0i
dHJ1ZSI+DSAgICAgICAgIDxtZW51DSAgICAgICAgICAgICAgIGlkPSJzY2Vu ZVNlbGVjdCIN
ICAgICAgICAgICAgICAgbGFiZWw9IiZhbXA7T3BlbkdMIj4NICAgICAgICAg ICAgPHNlcGFy
YXRvciBuYW1lPSJzZWxlY3RHcm91cCIvPg0gICAgICAgICA8L21lbnU+DSAg ICAgICAgIDxh
Y3Rpb24NICAgICAgICAgICAgICAgY2xhc3M9ImNvbS5nZW9meC5vcGVuZ2wu c2NlbmUuc2Vs
ZWN0LlNjZW5lU2VsZWN0Ig0gICAgICAgICAgICAgICBpY29uPSJpY29ucy9v Z2xfc21fc3F1
YXJlLmdpZiINICAgICAgICAgICAgICAgaWQ9ImNvbS5nZW9meC5vcGVuZ2wu dmlldy5hY3Rp
b25zLlNlbGVjdFNjZW5lIg0gICAgICAgICAgICAgICBsYWJlbD0iJmFtcDtT ZWxlY3QgU2Nl
bmUiDSAgICAgICAgICAgICAgIG1lbnViYXJQYXRoPSJzY2VuZVNlbGVjdC9z ZWxlY3RHcm91
cCINICAgICAgICAgICAgICAgdG9vbGJhclBhdGg9InNlbGVjdEdyb3VwIg0g ICAgICAgICAg
ICAgICB0b29sdGlwPSJTZWxlY3QgU2NlbmUiLz4NICAgICAgPC9hY3Rpb25T ZXQ+DSAgIDwv
ZXh0ZW5zaW9uPg0NPC9wbHVnaW4+DQ==
Content-type: application/octet-stream; name="MANIFEST.MF"
filename="MANIFEST.MF"
TWFuaWZlc3QtVmVyc2lvbjogMS4wCkJ1bmRsZS1NYW5pZmVzdFZlcnNpb246 IDIKQnVuZGxl
LU5hbWU6IE9wZW5HTCBWaWV3IFBsdWctaW4KQnVuZGxlLVN5bWJvbGljTmFt ZTogY29tLmdl
b2Z4Lm9wZW5nbC52aWV3O3NpbmdsZXRvbjo9dHJ1ZQpCdW5kbGUtVmVyc2lv bjogMS4wLjAK
QnVuZGxlLUFjdGl2YXRvcjogY29tLmdlb2Z4Lm9wZW5nbC52aWV3LkFjdGl2 YXRvcgpCdW5k
bGUtTG9jYWxpemF0aW9uOiBwbHVnaW4KUmVxdWlyZS1CdW5kbGU6IG9yZy5l Y2xpcHNlLnVp
LAogb3JnLmVjbGlwc2UuY29yZS5ydW50aW1lCkVjbGlwc2UtTGF6eVN0YXJ0 OiB0cnVlCkJ1
bmRsZS1DbGFzc1BhdGg6IGxpYi9nbHVlZ2VuLXJ0LmphciwKIGxpYi9qb2ds Lmphcgo=
--B_3292641900_58659948--
Re: Plugin classloader error in 3.3 not in 3.2 [message #255394 is a reply to message #255390] Sat, 03 May 2008 09:51 Go to previous message
Sorry, correction. Works fine on machines with 3.2, but fails on 3.3.
On 5/3/08 6:44 AM, in article C441BA6A.365B2%riwright@adobe.com, "Ric
Wright" <riwright@adobe.com> wrote:
> Chris,
> code?
> Ric
>> Cheers,
>> ~ Chris
Previous Topic:need arm-linux-gcc
Next Topic:Error: CharScanner; panic: ClassNotFoundException:
Current Time: Sun Nov 16 21:47:25 EST 2025
Powered by FUDForum. Page generated in 0.08304 seconds
