Home » Eclipse Projects » Eclipse Platform » CVS: getting the list of directories
CVS: getting the list of directories [message #254675] Tue, 22 June 2004 10:56 Go to next message
I have a question about the CVS. How do you get the list of directories
available on the CVS server using pserver? As I understand it, this is not
possible with the standard CVS command line interface.
Curt
Re: CVS: getting the list of directories [message #254906 is a reply to message #254675] Wed, 23 June 2004 09:14 Go to previous message
We do this by faking a local sandbox at the repository root and running
a "cvs -n update". It can be done using the command line in the same way
(i.e. setup a shared folder whose CVS/Repository file contains a dot (.).
Michael
> Curt
Previous Topic:Problem in eclipse.buildScript ant task
Next Topic:Please Demonstrate use of the TextCellEditor
Current Time: Thu Jul 17 20:12:53 EDT 2025
Powered by FUDForum. Page generated in 0.04379 seconds
