Home » Newcomers » Newcomers » 'Content Types' locked extensions
'Content Types' locked extensions [message #254524] Tue, 22 April 2008 05:07 Go to next message
Hello
Under 'Preferences/General/Content Types' several extensions are locked
with a particular type (ie: *.s with 'Assembly Source File' ).
Is there a way to unlock these extensions ?
Thanks for your help
lg
Re: 'Content Types' locked extensions [message #254545 is a reply to message #254524] Tue, 22 April 2008 08:21 Go to previous message
lg,
I don't think so. This means that the content type is registered
against that extension in some plugin.xml itself so while you can make
the content apply to other extensions and you make make other content
types apply to *.s, you can't remove a registration that's done by the
installed plugin in the IDE.
Lg wrote:
> Hello
> locked with a particular type (ie: *.s with 'Assembly Source File' ).
> lg
Previous Topic:IDE for cross compiling application for Intel X-scale processor
Next Topic:org.eclipse.wst.sse.ui
Current Time: Sat Jul 26 00:16:40 EDT 2025
Powered by FUDForum. Page generated in 0.30388 seconds
