Home » Eclipse Projects » Eclipse Platform » HELP SYSTEM / OSGI - org.eclipse.help.ui has already been stopped
HELP SYSTEM / OSGI - org.eclipse.help.ui has already been stopped [message #254487] Tue, 22 June 2004 04:02 Go to next message
I switched to RC3 and I get following error in my RCP Application.
I start it, open the help ( everything shows up and runs ).
When I close the application it throws a ClassNotFoundException ->
java.lang.ClassNotFoundException: The class
" org.eclipse.help.ui.internal.browser.embedded.EmbeddedBrowse rAdapter$2 "
cannot be loaded because the system is shutting down and the plug-in
"org.eclipse.help.ui" has already been stopped.
It is clear that OSGI has stopped the org.eclipse.help.ui to early.
I wonder if I can somehow define in what order the OSGI Bundles are
stopped. Well I know we can do that in the .ini file for starting the
Bundles... Do they stop in the same order (first loaded, last stopped)
as well ?
Can I configure the shutdown sequence when I use the
org.eclipse.update.configurator ?
Tom
stack trace :
!ENTRY org.eclipse.osgi Jun 22, 2004 09:47:04.743
!MESSAGE The class
!STACK 0
org.eclipse.core.runtime.adaptor.EclipseClassLoader.shouldAc tivateFor(EclipseClassLoader.java:147)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:62)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:371)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
org.eclipse.help.ui.internal.browser.embedded.EmbeddedBrowse rAdapter.close(EmbeddedBrowserAdapter.java:56)
org.eclipse.help.internal.browser.BrowserManager.closeAll(Br owserManager.java:330)
org.eclipse.help.internal.base.BaseHelpSystem.shutdown(BaseH elpSystem.java:120)
org.eclipse.help.internal.base.HelpBasePlugin.stop(HelpBaseP lugin.java:93)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:994)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:990)
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:502)
org.eclipse.osgi.framework.internal.core.AbstractBundle.stop (AbstractBundle.java:437)
org.eclipse.core.runtime.adaptor.BundleStopper.basicStopBund les(BundleStopper.java:75)
org.eclipse.core.runtime.adaptor.BundleStopper.stopBundles(B undleStopper.java:62)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSto pping(EclipseAdaptor.java:551)
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:457)
org.eclipse.osgi.framework.internal.core.SystemBundle$1.run( SystemBundle.java:182)
at java.lang.Thread.run(Thread.java:534)
!ENTRY org.eclipse.osgi Jun 22, 2004 09:47:04.763
!MESSAGE Error while stopping "org.eclipse.help.base_3.0.0".
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.help.internal.base.HelpBasePlugin.stop() of bundle
org.eclipse.help.base.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1010)
Caused by: java.lang.NoClassDefFoundError:
org/eclipse/help/ui/internal/browser/embedded/EmbeddedBrowse rAdapter$2
... 8 more
Root exception:
Re: HELP SYSTEM / OSGI - org.eclipse.help.ui has already been stopped [message #254631 is a reply to message #254487] Tue, 22 June 2004 07:54 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
The bundles are shutdown in the reverse order of the prerequisite (for
example UI, then resources, then runtime). If you get such errors it is
probably because some threads have not been stopped or jobs are still
running.
If you can provide a bug report open a bug report against Help and CC'me
PaScaL
> as well ?
> Tom
> stack trace :
> !MESSAGE The class
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 8 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: HELP SYSTEM / OSGI - org.eclipse.help.ui has already been stopped [message #254680 is a reply to message #254631] Tue, 22 June 2004 11:18 Go to previous message
It was a problem in my code, I could solve it... (no bug)
Thanx
Tom
> running.
> PaScaL
>> as well ?
>> Tom
>> stack trace :
>> !MESSAGE The class
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 8 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:Why I cannot see the resources in a RCP application
Next Topic:[Compare] Change 2 files in the compare view and save them - comparison is performed two times.
Current Time: Fri Nov 07 06:24:08 EST 2025
Powered by FUDForum. Page generated in 0.03242 seconds
