Home » Archived » BIRT » BIRT 2.2 Simple Example RunAndRenderTask
| BIRT 2.2 Simple Example RunAndRenderTask [message #254445] |
Tue, 04 September 2007 16:00  |
Originally posted by: calmacroi.myrddin.ch
hi
i've worked with birt 2.0.1. now i try to use birt 2.2.0. i get crazy
cause i just tried a simple example and it doesnt work.
thanks for any help.
here is my example code:
import java.util.HashMap;
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.impl.ReportEngine;
public class BirtTest {
public BirtTest() {
BirtTest test = new BirtTest();
test.createEngine();
public void createReport(IReportEngine engine) throws EngineException{
// Open a report design - use design to modify design, retrieve
embedded images etc.
IReportRunnable design =
engine.openReportDesign("D:/temp/PS4Report.rptdesign");
// Create task to run the report and render the report
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
// Set Render context to handle url and image locataions
HTMLRenderContext renderContext = new HTMLRenderContext();
renderContext.setImageDirectory("image");
HashMap contextMap = new HashMap();
contextMap.put( EngineConstants.APPCONTEXT_HTML_RENDER_CONTEXT,
renderContext );
task.setAppContext( contextMap );
// Set rendering options - such as file or stream output,
// output format, whether it is embeddable, etc
HTMLRenderOption options = new HTMLRenderOption();
// options.setOutputStream(System.out);
options.setOutputFileName("d:/temp/report.html");
options.setOutputFormat("html");
task.setRenderOption(options);
task.run();
public void createEngine() {
EngineConfig config = null;
ReportEngine engine = null;
try{
config = new EngineConfig( );
config.setEngineHome( "D:/Java/birt-runtime-2_2_0/ReportEngine" );
config.setLogConfig("d:/temp", Level.FINE);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = (ReportEngine)factory.createReportEngine( config );
engine.changeLogLevel( Level.WARNING );
}catch( Exception ex){
ex.printStackTrace();
try
// Run reports, etc.
createReport(engine);
// Shut down the engine.
engine.shutdown();
Platform.shutdown();
catch ( EngineException e1 )
// Ignore
| Re: BIRT 2.2 Simple Example RunAndRenderTask [message #254454 is a reply to message #254445] |
Tue, 04 September 2007 16:59   |
Patrick,
Make sure you updated your libs in your build path to point to the 2.2
libs. Here is an example of the runandrender task that works in my
environment.
Jason
package REAPI;
import org.eclipse.birt.report.engine.api.HTMLActionHandler;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.HTMLCompleteImageHandler;
import org.eclipse.birt.report.engine.api.RenderOption;
public class RunAndRenderTask {
public void runReport() throws EngineException
IReportEngine engine=null;
try{
//System.setProperty("java.io.tmpdir", "c:/temp/test/testsampledb");
config.setBIRTHome(" C:\\birt\\birt-runtime-2_2_0\\birt-runtime-2_2_0\\ReportEngi ne ");
config.setLogConfig("c:/temp/test", Level.FINEST);
engine = factory.createReportEngine( config );
IReportRunnable design = null;
//Open the report design
design = engine.openReportDesign("Reports/TopNPercent.rptdesign");
//Create task to run and render the report,
task.setParameterValue("Top Percentage", (new Integer(3)));;
task.setParameterValue("Top Count", (new Integer(5)));
//task.validateParameters();
options.setOutputFileName("output/resample/TopNPercent.html ");
options.setHtmlRtLFlag(false);
options.setEmbeddable(false);
options.setImageDirectory("C:\\apps\\apache-tomcat-5.5.20\\webapps\\2.2\\images ");
options.setBaseImageURL("http://localhost:8080/2.2/images/");
//ImageHandlerTest
options.setImageHandler(new MyImageHandler());
//options.setImageHandler(new HTMLServerImageHandler());
//options.setImageHandler(new HTMLCompleteImageHandler());
//options.setBaseImageURL("http://localhost/imageGetter?");
//CancelReport cancelThread = new CancelReport( "cancelReport", task);
//cancelThread.start();
//long beginTime = System.currentTimeMillis();
task.run();
//long endTime = System.currentTimeMillis();
//long timeSpan = endTime - beginTime;
//System.out.println("Report Runtime: " + timeSpan);
//int teststatus = task.getStatus();
//if( teststatus == 4){
// System.out.println("Report was cancelled");
task.close();
//task = engine.createRunAndRenderTask(design);
//task.setParameterValue("Top Percentage", (new Integer(3)));
//task.setParameterValue("Top Count", (new Integer(5)));
//task.setRenderOption(options);
//beginTime = System.currentTimeMillis();
//task.run();
//endTime = System.currentTimeMillis();
//timeSpan = endTime - beginTime;
//teststatus = task.getStatus();
//if( teststatus == 2){
// System.out.println("Report Completed");
//task.close();
engine.destroy();
finally
Platform.shutdown( );
System.out.println("Finished");
* @param args
try
RunAndRenderTask ex = new RunAndRenderTask( );
ex.runReport();
catch ( Exception e )
e.printStackTrace();
private class CancelReport extends Thread
private IRunAndRenderTask rTask;
public CancelReport( String threadName, IRunAndRenderTask task){
super(threadName);
rTask = task;
public void run()
try{
Thread.currentThread().sleep( 100 );
rTask.cancel();
System.out.println("######Report Cancelled#######");
catch(Exception e)
Patrick wrote:
> hi
> public BirtTest() {
> public static void main(String[] args) {
> renderContext );
> task.run();
> try{
> try
> engine.shutdown();
> // Ignore
| Re: BIRT 2.2 Simple Example RunAndRenderTask [message #254527 is a reply to message #254454] |
Wed, 05 September 2007 05:47   |
hi jason
thanks for your example, but in my environment it doesnt work. the
exception appears:
----snipp snipp
05.09.2007 11:39:33
org.eclipse.birt.report.data.oda.sampledb.SampledbPlugin start
INFO: Sampledb plugin starts up. Current startCount=0
05.09.2007 11:39:33
org.eclipse.birt.report.data.oda.sampledb.SampledbPlugin init
INFO: Creating Sampledb database at location
C:\DOCUME~1\pkistler\LOCALS~1\Temp\/BIRTSampleDB_11889851733 28_391da0
org.eclipse.birt.report.model.metadata.ChoicePropertyType.va lidateXml(ChoicePropertyType.java:118)
org.eclipse.birt.report.model.metadata.PropertyDefn.validate Xml(PropertyDefn.java:762)
org.eclipse.birt.report.model.metadata.PeerExtensionLoader$P eerExtensionElementLoader.loadProperty(PeerExtensionLoader.j ava:263)
org.eclipse.birt.report.model.metadata.PeerExtensionLoader$P eerExtensionElementLoader.loadElement(PeerExtensionLoader.ja va:162)
org.eclipse.birt.report.model.metadata.PeerExtensionLoader.l oadExtension(PeerExtensionLoader.java:75)
org.eclipse.birt.report.model.metadata.ExtensionLoader.doLoa d(ExtensionLoader.java:135)
org.eclipse.birt.report.model.metadata.ExtensionLoader.load( ExtensionLoader.java:72)
org.eclipse.birt.report.model.metadata.ExtensionManager.init ialize(ExtensionManager.java:39)
org.eclipse.birt.report.model.api.impl.DesignEngineImpl.init ialize(DesignEngineImpl.java:99)
org.eclipse.birt.report.model.api.impl.DesignEngineImpl.newS essionHandle(DesignEngineImpl.java:142)
org.eclipse.birt.report.model.api.DesignEngine.newSessionHan dle(DesignEngine.java:106)
org.eclipse.birt.report.model.api.DesignEngine.newSession(De signEngine.java:128)
org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportParser.java:144)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:243)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:191)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:125)
org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDesign(ReportEngine.java:235)
at ch.spf.PS4Gui.Report.RunReport.runReport(RunReport.java:55)
at ch.spf.PS4Gui.Report.RunReport.main(RunReport.java:95)
Finished
----snipp snipp
please help me, i get crazy using birt... thanks very much for further help!
the only reason to update is that in birt 2.0.1 sometimes a part of the
pdf report will not be displayed and the SaxParser sometimes throws an
exception (i use xmldatasource)
it got my code working in my project but then the most part of the
report doesnt appear (may cause of the old design file?)
i ordered your book, but this is defined for birt 2.1.x i guess.
we are thinking about not using birt or actuate birt at all because for
our xml input it takes about 60s to generate a report and i never had so
much problems to get an external software working.
regs patrick
Jason Weathersby schrieb:
> Patrick,
> environment.
> Jason
> package REAPI;
> try{
> //ImageHandlerTest
> task);
> task.run();
> task.close();
> //task.run();
> //task.close();
> engine.destroy();
> finally
> * @param args
> try
> ex.runReport();
> super(threadName);
> rTask = task;
> public void run()
> try{
> rTask.cancel();
> catch(Exception e)
> Patrick wrote:
>> hi
>> public BirtTest() {
>> EngineException{
>> report
>> locataions
>> contextMap.put(
>> EngineConstants.APPCONTEXT_HTML_RENDER_CONTEXT, renderContext );
>> stream output,
>> task.run();
>> try{
>> Platform
>> try
>> engine.shutdown();
>> // Ignore
| Re: BIRT 2.2 Simple Example RunAndRenderTask [message #254564 is a reply to message #254527] |
Wed, 05 September 2007 19:50   |
Patrick,
Can you post the report?
Can you also open a bugzilla entry for the report?
Jason
Patrick wrote:
> hi jason
> exception appears:
> ----snipp snipp
> 05.09.2007 11:39:33
> 05.09.2007 11:39:33
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Finished
> ----snipp snipp
> help!
> regs patrick
>> Patrick,
>> environment.
>> Jason
>> package REAPI;
>> try{
>> "c:/temp/test/testsampledb"); config = new EngineConfig(
>> Platform
>> design =
>> HTMLRenderOption();
>> //ImageHandlerTest
>> task.run();
>> task.close();
>> //task.run();
>> //} //task.close();
>> engine.destroy();
>> } finally
>> * @param args
>> try
>> ex.runReport();
>> super(threadName);
>> rTask = task;
>> public void run()
>> try{
>> rTask.cancel();
>> catch(Exception e)
>> Patrick wrote:
>>> hi
>>> public BirtTest() {
>>> EngineException{
>>> retrieve embedded images etc.
>>> report
>>> locataions
>>> contextMap.put(
>>> stream output,
>>> task.run();
>>> try{
>>> Platform
>>> try
>>> engine.shutdown();
>>> // Ignore
| Re: BIRT 2.2 Simple Example RunAndRenderTask [message #254592 is a reply to message #254564] |
Thu, 06 September 2007 03:22   |
--------------030306050505080102080504
hi jason
here is the report and the releated xml source. the thing with
>> the pdf report will not be displayed and the SaxParser sometimes
>> throws an exception (i use xmldatasource)
that happend with birt 2.0.1 and i hope it doesn't with the actual version.
so does it make sense to open a ticket for a bug in 2.0.1 as long as it
doesn't happen with the actual birt?
thanks much for your help
regs
patrick
> Patrick,
> Jason
> Patrick wrote:
>> hi jason
>> exception appears:
>> ----snipp snipp
>> 05.09.2007 11:39:33
>> 05.09.2007 11:39:33
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Finished
>> ----snipp snipp
>> help!
>> for our xml input it takes about 60s to generate a report and i never
>> had so much problems to get an external software working.
>> regs patrick
>>> Patrick,
>>> 2.2 libs. Here is an example of the runandrender task that works in
>>> my environment.
>>> Jason
>>> package REAPI;
>>> try{
>>> EngineConfig( );
>>> Platform
>>> design =
>>> HTMLRenderOption();
>>> //ImageHandlerTest
>>> task.run();
>>> task.close();
>>> //task =
>>> //task.run();
>>> //} //task.close();
>>> engine.destroy();
>>> } finally
>>> * @param args
>>> try
>>> ex.runReport();
>>> super(threadName);
>>> rTask = task;
>>> public void run()
>>> try{
>>> rTask.cancel();
>>> catch(Exception e)
>>> Patrick wrote:
>>>> hi
>>>> crazy cause i just tried a simple example and it doesnt work.
>>>> public BirtTest() {
>>>> EngineException{
>>>> the report
>>>> locataions
>>>> contextMap.put(
>>>> stream output,
>>>> task.run();
>>>> try{
>>>> Platform
>>>> config );
>>>> try
>>>> engine.shutdown();
>>>> // Ignore
Content-Type: text/xml;
name="PS4Report.rptdesign"
Content-Disposition: inline;
filename="PS4Report.rptdesign"
<?xml version=3D"1.0" encoding=3D"UTF-8"?>
<report xmlns=3D"http://www.eclipse.org/birt/2005/design" version=3D"3.2.=
14" id=3D"1">
<property name=3D"author">P. Kistler</property>
<property name=3D"createdBy">Eclipse BIRT Designer Version 2.0.1 Buil=
d <20060222-1204></property>
<property name=3D"units">cm</property>
<method name=3D"initialize"><![CDATA[myImage =3D variantImage;]]></me=
thod>
<data-sources>
<oda-data-source extensionID=3D"org.eclipse.datatools.enablement.=
oda.xml" name=3D"ReportData" id=3D"168">
<property name=3D"FILELIST">d:\temp\ReportData.xml</property>=
</oda-data-source>
<script-data-source name=3D"Scripted Images" id=3D"482"/>
</data-sources>
<data-sets>
<oda-data-set extensionID=3D"org.eclipse.datatools.enablement.oda=
=2Exml.dataSet" name=3D"Meteodata" id=3D"259">
<structure name=3D"cachedMetaData">
<list-property name=3D"resultSet">
<structure>
<property name=3D"position">1</property>
<property name=3D"name">value1</property>
<property name=3D"dataType">string</property>
</structure>
<structure>
<property name=3D"position">2</property>
<property name=3D"name">value2</property>
</structure>
<structure>
<property name=3D"position">3</property>
<property name=3D"name">value3</property>
</structure>
<structure>
<property name=3D"position">4</property>
<property name=3D"name">value4</property>
</structure>
<structure>
<property name=3D"position">5</property>
<property name=3D"name">col1</property>
</structure>
<structure>
<property name=3D"position">6</property>
<property name=3D"name">col2</property>
</structure>
<structure>
<property name=3D"position">7</property>
<property name=3D"name">col3</property>
</structure>
<structure>
<property name=3D"position">8</property>
<property name=3D"name">col4</property>
</structure>
<structure>
<property name=3D"position">9</property>
<property name=3D"name">tableName</property>
</structure>
<structure>
<property name=3D"position">10</property>
<property name=3D"name">sectionName</property>
</structure>
</list-property>
</structure>
<property name=3D"dataSource">ReportData</property>
<structure>
<property name=3D"nativeName">value1</property>
</structure>
<structure>
<property name=3D"nativeName">value2</property>
</structure>
<structure>
<property name=3D"nativeName">value3</property>
</structure>
<structure>
<property name=3D"nativeName">value4</property>
</structure>
<structure>
<property name=3D"nativeName">col1</property>
</structure>
<structure>
<property name=3D"nativeName">col2</property>
</structure>
<structure>
<property name=3D"nativeName">col3</property>
</structure>
<structure>
<property name=3D"nativeName">col4</property>
</structure>
<structure>
<property name=3D"nativeName">tableName</property>
</structure>
<structure>
<property name=3D"nativeName">sectionName</property>
</structure>
</list-property>
<property name=3D"queryText">table0#-TNAME-#table0#:#[/report=
/section[2]/table[1]/row]#:#{value1;String;/value1},{value2; String;/value=
2},{value3;String;/value3},{value4;String;/value4},{col1;Str ing;../column=
Definition/col1},{col2;String;../columnDefinition/col2},{col 3;String;../c=
olumnDefinition/col3},{col4;String;../columnDefinition/col4} ,{tableName;S=
tring;../@name},{sectionName;String;../../@name}</property>
<list-property name=3D"privateDriverProperties">
<ex-property>
<name>MAX_ROW</name>
<value>-1</value>
</ex-property>
<ex-property>
<name>XML_FILE</name>
<value>d:\temp\ReportData.xml</value>
</ex-property>
</list-property>
</oda-data-set>
=2Exml.dataSet" name=3D"Verbraucher" id=3D"266">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name=3D"name">value5</property>
</structure>
<structure>
<property name=3D"name">value6</property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name=3D"position">11</property>
<property name=3D"name">col5</property>
</structure>
<structure>
<property name=3D"position">12</property>
<property name=3D"name">col6</property>
</structure>
<structure>
<property name=3D"position">13</property>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name=3D"nativeName">value5</property>
</structure>
<structure>
<property name=3D"nativeName">value6</property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name=3D"nativeName">col5</property>
</structure>
<structure>
<property name=3D"nativeName">col6</property>
</structure>
<structure>
</structure>
</list-property>
/section[2]/table[2]/row]#:#{col1;String;../../table[2]/colu mnDefinition/=
col1},{value1;String;../../table[2]/row/value1},{value2;Stri ng;../../tabl=
e[2]/row/value2},{value3;String;../../table[2]/row/value3},{ value4;String=
;../../table[2]/row/value4/},{value5;String;../../table[2]/r ow/value5},{v=
alue6;String;../../table[2]/row/value6},{col2;String;../../t able[2]/colum=
nDefinition/col2},{col3;String;../../table[2]/columnDefiniti on/col3},{col=
4;String;../../table[2]/columnDefinition/col4},{col5;String; ../../table[2=
]/columnDefinition/col5},{col6;String;../../table[2]/columnD efinition/col=
6},{tableName;String;../../table[2]/@name}</property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
=2Exml.dataSet" name=3D"Anlage Definition" id=3D"337">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
/section[2]/table[3]/row]#:#{value1;String;../../table[3]/ro w/value1},{va=
lue2;String;../../table[3]/row/value2},{value3;String;../../ table[3]/row/=
value3},{value4;String;../../table[3]/row/value4},{tableName ;String;../..=
/table[3]/@name},{col1;String;../../table[3]/columnDefinitio n/col1},{col2=
;String;../../table[3]/columnDefinition/col2},{col3;String;. ./../table[3]=
/columnDefinition/col3},{col4;String;../../table[3]/columnDe finition/col4=
}</property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
<script-data-set name=3D"Images" id=3D"483">
<list-property name=3D"resultSetHints">
<structure>
<property name=3D"name">companyImage</property>
<property name=3D"dataType">any</property>
</structure>
<structure>
<property name=3D"name">projectImage</property>
</structure>
<structure>
<property name=3D"name">variantImage</property>
</structure>
</list-property>
<list-property name=3D"columnHints">
<structure>
<property name=3D"columnName">companyImage</property>=
</structure>
<structure>
<property name=3D"columnName">projectImage</property>=
</structure>
<structure>
<property name=3D"columnName">variantImage</property>=
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name=3D"dataSource">Scripted Images</property>
</script-data-set>
=2Exml.dataSet" name=3D"MasterPage" id=3D"555">
<structure>
<property name=3D"name">footerInfo</property>
</structure>
<structure>
<property name=3D"name">headerInfo</property>
</structure>
</list-property>
</structure>
<structure>
<property name=3D"nativeName">footerInfo</property>
</structure>
<structure>
<property name=3D"nativeName">headerInfo</property>
</structure>
</list-property>
/masterPage]#:#{footerInfo;String;/footerInfo},{headerInfo;S tring;/header=
Info}</property>
<ex-property>
<value>14</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
=2Exml.dataSet" name=3D"Report Infos" id=3D"577">
<structure>
<property name=3D"name">reportName</property>
</structure>
</list-property>
</structure>
<structure>
<property name=3D"nativeName">reportName</property>
</structure>
</list-property>
]#:#{reportName;String;/@name}</property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
=2Exml.dataSet" name=3D"Overview" id=3D"605">
<structure>
<property name=3D"name">R1C2-name</property>
</structure>
<structure>
<property name=3D"name">R1C2-title</property>
</structure>
<structure>
<property name=3D"name">R1C2-company</property>
</structure>
<structure>
<property name=3D"name">R1C2-address</property>
</structure>
<structure>
<property name=3D"name">R2C1</property>
</structure>
<structure>
<property name=3D"name">R2C2</property>
</structure>
<structure>
<property name=3D"name">R6C1</property>
<pro
| Re: BIRT 2.2 Simple Example RunAndRenderTask [message #254838 is a reply to message #254592] |
Mon, 10 September 2007 10:52  |
Patrick,
I did not see anything obvious that is wrong in the report (other than
not finding some images). This worked in my 2.2 designer. Is it
working in your designer?
Jason
Patrick wrote:
> hi jason
> regs
> patrick
>> Patrick,
>> Jason
>> Patrick wrote:
>>> hi jason
>>> exception appears:
>>> ----snipp snipp
>>> 05.09.2007 11:39:33
>>> 05.09.2007 11:39:33
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Finished
>>> ----snipp snipp
>>> further help!
>>> regs patrick
>>>> Patrick,
>>>> my environment.
>>>> Jason
>>>> package REAPI;
>>>> try{
>>>> EngineConfig( );
>>>> Platform
>>>> design =
>>>> HTMLRenderOption();
>>>> //ImageHandlerTest
>>>> task.run();
>>>> task.close();
>>>> //task =
>>>> //task.run();
>>>> //} //task.close();
>>>> engine.destroy();
>>>> } finally
>>>> * @param args
>>>> try
>>>> ex.runReport();
>>>> task){
>>>> super(threadName);
>>>> rTask = task;
>>>> public void run()
>>>> try{
>>>> rTask.cancel();
>>>> catch(Exception e)
>>>> Patrick wrote:
>>>>> hi
>>>>> public BirtTest() {
>>>>> EngineException{
>>>>> the report
>>>>> locataions
>>>>> contextMap.put(
>>>>> stream output,
>>>>> task.run();
>>>>> try{
>>>>> Platform
>>>>> config );
>>>>> try
>>>>> engine.shutdown();
>>>>> // Ignore
Current Time: Thu Nov 06 16:43:43 EST 2025
Powered by FUDForum. Page generated in 0.04125 seconds
