| TreeItems [message #254217] |
Mon, 21 June 2004 08:52  |
Originally posted by: JWessling.gmx.de
Hi.
How can i expand TreeItems?
The tree is filled correct, there is a cross next to the Element that
has children, I get the TreeEvent that shows that the tree will be
expanded, but I don't see it. I tried in the treeExpanded-method
to update or redraw the tree. I set the item to setExpanded(true)
and I tried tree.showItem() for every item that is hierachily under
my expanded item, but the only thing happen, is that the cross beside my
item disappears.
Jan
| Re: TreeItems [message #254506 is a reply to message #254369] |
Tue, 22 June 2004 04:27  |
Michael Keppler wrote:
> Jan Wessling schrieb:
>> Hi.
>> has children,
> At least on Windows, a tree item also has a plus sign if the tree does
> not yet know if there are children.
>> item disappears.
> Sounds exactly like having no child and the plus sign disappearing when
> the tree knows about it after the unsuccessful try to show then children.
> So please check your code if you _really_ add children to the item.
When debugging and examining the tree, the treeitems are added under the
top-level items. But when the event appears, the tree only has the
top-level elements. I tried out to make the tree more global, but the
same happens as described above.
CU
Jan
> Ciao, Michael.
FUDForum. Page generated in 0.02488 seconds
