Home » Archived » BIRT » Image URL in HTML report is wrong
Image URL in HTML report is wrong [message #254064] Fri, 31 August 2007 05:57 Go to next message
Originally posted by: dominik.spitzer.web.de
I found some posts with a similar problem, but no solution that helped me.
The problem is, that the generated HTML from a report contains image url
like this: "file:/jboss-4.0.3.sp1/server/default/.../images/image.png"
when should look like this: "www.mydomain.com/MyWebApp/images/image.png"
or at least "/MyWebApp/images/image.png".
I'm using code like the following to set up the engine:
class MyServlet extends HttpServlet {
private void doGet(HttpServletRequest req, HttpServletResponse resp) {
resp.setContentType("text/html");
String reportName = req.getParameter("report");
ServletContext sc = req.getSession().getServletContext();
IReportRunnable design;
if (engine == null) {
// create report engine
EngineConfig config = new EngineConfig();
config.setEngineHome("");
config.setLogConfig(null, Level.WARNING);
try {
Platform.startup(config);
IReportEngineFactory factory = (IReportEngineFactory)
Platform.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY);
engine = factory.createReportEngine(config);
engine.changeLogLevel(Level.WARNING);
//Open report design
design = viewer.openReportDesign(sc.getRealPath("/reports/"
+ reportName));
//set output options
HTMLRenderOption opt = new HTMLRenderOption();
opt.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_HTML);
opt.setOutputStream(resp.getOutputStream());
opt.setBaseImageURL(req.getContextPath() + "/images");
opt.setImageDirectory(sc.getRealPath("/images"));
//create task to run and render report
IRunAndRenderTask task =
engine.createRunAndRenderTask(report);
task.setRenderOption(option);
task.run();
task.close();
} catch (BirtException e) {
System.out.println("Platform startup failed");
e.printStackTrace();
Thanks for your help!
Dominik
Re: Image URL in HTML report is wrong [message #254068 is a reply to message #254064] Fri, 31 August 2007 05:59 Go to previous messageGo to next message
Sorry, I forgot. I'm using Eclipse 3.3.0 and BIRT 2.2.0 on JBoss 4.0.3.SP1.
Dominik Spitzer schrieb:
> try {
> + reportName));
> task.run();
> task.close();
> Dominik
Re: Image URL in HTML report is wrong [message #254076 is a reply to message #254064] Fri, 31 August 2007 07:03 Go to previous message
Ok, I fixed this myself. I had to use a HTMLServerImageHandler. Sorry
for spaming the list! ;-)
Greetings, Dominik
> try {
> + reportName));
> task.run();
> task.close();
> Dominik
Previous Topic:birt 2.2 fails to locate java classes in importPackage script statements
Next Topic:Table Of Contents as a report item
Current Time: Tue Jul 22 00:53:43 EDT 2025
Powered by FUDForum. Page generated in 0.04955 seconds
