Home » Archived » BIRT » Trying to "append" multiple rptdesigns to single output (HTML, BIRT 2.2)
Trying to "append" multiple rptdesigns to single output (HTML, BIRT 2.2) [message #254015] Thu, 30 August 2007 15:30 Go to next message
Originally posted by: chesser_z.yahoo.com
Does anyone know how to append multiple rptdesigns into the same output? I
am using HTML output currently.
The examples I see for "Compound reports" seem like just one rptdesign with
multiple data sources. Also called "sub-reporting".
The main reason is that I have a cross tab and two charts that will be
called with different data about 10 times. These should all be in the same
file as a "report" so the user can view it. I don't want to have one large
rptdesign where I copy and paste everything and possibly have problems with
the overall width of the items.
If this is possible, do you know if I can set a layout of how it appends?
i.e. append 3 reports per row, then line break?
My workaround currently would be to merge the reports with my own code
afterwards via parsing.
John
Re: Trying to "append" multiple rptdesigns to single output (HTML, BIRT 2.2) [message #254023 is a reply to message #254015] Thu, 30 August 2007 16:46 Go to previous messageGo to next message
I found one way that I think will work,
((HTMLRenderOption)renderOption).setEmbeddable(true);
along with setting the output stream to the same file.
Going to give it a try.
"John Chesser" <chesser_z@yahoo.com> wrote in message
news:fb75s3$56b$1@build.eclipse.org...
> I
> with
> same
> large
> with
> John
Re: Trying to "append" multiple rptdesigns to single output (HTML, BIRT 2.2) [message #254027 is a reply to message #254023] Thu, 30 August 2007 18:30 Go to previous message
--------------090905030107070201090605
John,
Here are two examples:
one to combine html
another to combine pdf
Jason
>> I
>> with
>> same
>> large
>> with
>> Thanks,
>> John
Content-Type: java/*;
name="CombineReportsPDF.java"
Content-Disposition: inline;
filename="CombineReportsPDF.java"
package REAPI;
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import java.io.FileOutputStream;
import java.io.ByteArrayOutputStream;
import com.lowagie.text.pdf.PdfReader;
import com.lowagie.text.pdf.PdfCopyFields;
public class CombineReportsPDF {
public void concat(byte[] ba1, byte[] ba2, String outpath){
try{
PdfReader rd1 = new PdfReader( ba1 );
PdfReader rd2 = new PdfReader( ba2 );
PdfCopyFields cpy = new PdfCopyFields( new FileOutputStream( outpath ));
cpy.addDocument(rd1);
cpy.addDocument(rd2);
cpy.close();
}catch(Exception e){
e.printStackTrace();
public void runReport() throws EngineException
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
config.setBIRTHome(" C:\\birt\\birt-runtime-2_2_0\\birt-runtime-2_2_0\\ReportEngi ne ");
config.setLogConfig(null, Level.OFF);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject( IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
}catch( Exception ex){
ex.printStackTrace();
IReportRunnable design, design2 = null;
//Open the report design
design = engine.openReportDesign("Reports/TopNPercent.rptdesign");
design2 = engine.openReportDesign("Reports/TopSellingProducts.rptdesign ");
//Create task to run and render the report,
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
task.setParameterValue("Top Percentage", (new Integer(3)));
task.setParameterValue("Top Count", (new Integer(5)));
task.validateParameters();
PDFRenderOption options = new PDFRenderOption();
ByteArrayOutputStream fso= new ByteArrayOutputStream();
ByteArrayOutputStream fso2= new ByteArrayOutputStream();
options.setOutputStream(fso);
options.setOutputFormat("pdf");
task.setRenderOption(options);
task.run();
task.close();
task = engine.createRunAndRenderTask(design2);
options.setOutputStream(fso2);
task.run();
task.close();
concat( fso.toByteArray(), fso2.toByteArray(), "output/resample/Combined.pdf");
engine.destroy();
Platform.shutdown();
System.out.println("Finished");
* @param args
try
CombineReportsPDF ex = new CombineReportsPDF( );
ex.runReport();
catch ( Exception e )
name="CombineReports.java"
filename="CombineReports.java"
package REAPI;
import java.util.HashMap;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.HTMLActionHandler;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.HTMLCompleteImageHandler;
import org.eclipse.birt.report.engine.api.RenderOption;
import java.io.File;
public class CombineReports {
try{
HTMLRenderOption options = new HTMLRenderOption();
FileOutputStream fso=null, fso2=null;
try{
fso = new FileOutputStream(new File("output/resample/Combined.html"), true);
}catch (Exception e){
options.setEmbeddable(true);
options.setOutputFormat("html");
options.setImageDirectory("images");
//ImageHandlerTest
//options.setImageHandler(new MyImageHandler());
//options.setImageHandler(new HTMLServerImageHandler());
options.setImageHandler(new HTMLCompleteImageHandler());
task.run();
try{
fso.flush();
fso.close();
fso2 = new FileOutputStream(new File("output/resample/Combined.html"), true);
task.run();
task.close();
try{
fso2.flush();
fso2.close();
engine.destroy();
* @param args
try
CombineReports ex = new CombineReports( );
ex.runReport();
private class CancelReport extends Thread
private IRunAndRenderTask rTask;
public CancelReport( String threadName, IRunAndRenderTask task){
super(threadName);
rTask = task;
public void run()
try{
Thread.currentThread().sleep( 100 );
rTask.cancel();
System.out.println("######Report Cancelled#######");
catch(Exception e)
--------------090905030107070201090605--
Previous Topic:Socket Timeout Error
Next Topic:birt 2.2 fails to locate java classes in importPackage script statements
Current Time: Sat Nov 08 10:19:40 EST 2025
Powered by FUDForum. Page generated in 0.03779 seconds
