Home » Archived » BIRT » RCP, scripted datasource and classpath
RCP, scripted datasource and classpath [message #253896] Wed, 29 August 2007 16:55 Go to next message
Originally posted by: mail.micke.gmail.com
I have been trying to figure out how to integrate BIRT into an RCP
application when using a scripted datasource.
I've seen this question anwsered elsewhere in the forum but I haven't
managed to get it working.
Especially this thread "Custom classes are not found in
ScriotedDataSource in my RCP app" which had a lot of deprecated things
in it. Is there a good place to find documentation about the
EngineConstants? Checked the javadoc but wasn't that many comments about
it. Also couldn't find the ReportEngineService class used in the example
code.
First of, is it possible to get BIRT to pick up classes in the normal
classpath? I really don't want to copy the classes into the web-inf
folder of the viewer (perhaps this is the old way of doing it).
If not how do you guys deal with packaging and developing your
applications using scripted datasources in a pain less way.
As a base for my test application I use the BIRT RCP Viewer found here:
http://wiki.eclipse.org/index.php/RCP_Example
Using:
BIRT 2.2
Eclipse 3.3
Would be really grateful for responses.
Mike
Re: RCP, scripted datasource and classpath [message #253937 is a reply to message #253896] Thu, 30 August 2007 03:02 Go to previous messageGo to next message
Originally posted by: suryakant.in.ibm.com
Hello Mike,
you have two solutions for the above problem.
In my case i was using a java standalone application with BIRT reporting
API to execute a report and was using scripted data source.
what is did, i had the Java class which i was accessing in the birt report
as scripted data source in the same eclipse project.
1. u can ste this property before staritng the platform
// Option 1
System.setProperty
(EngineConstants.WEBAPP_CLASSPATH_KEY,"./myclasses/myjar.jar " );
u can create jar of ur java clasees and can give that path in this call.
or
2.
// Option -
MyClass dSrc = new MyClass();
//runReport is on type IRunAndRenderTask//
runReport.addScriptableJavaObject("MyJavaScriptItem", dSrc );
// u can get more info at this place
http://www.eclipse.org/birt/phoenix/deploy/reportEngineAPI.p hp
u have miscellanesous section near the end of the page which will help u
with the above functioncall. Furthur the above funtion is depricated, so
u can use theoption that i have given below:
//You can use the application context object to do this. You can
set this for the task or the engine like:
DummyClass dl = new DummyClass();
Configure the Engine and start the Platform
config = new EngineConfig( );
HashMap hm = config.getAppContext();
hm.put( "dummy", dl);
config.setAppContext(hm);
// do these defore starting the platform
If you still be facing issues do revert back, will try my best to get it
resolved
Thanks and Regards
Surya
Re: RCP, scripted datasource and classpath [message #254004 is a reply to message #253896] Thu, 30 August 2007 14:00 Go to previous messageGo to next message
I had similar problems. See this thread (before and after the post in this
link) I went through a lot and finally worked out solutions for all, I now
run BIRT viewer in a RCP with scripted data set that access the classes in
other plug-ins of my RCP app.
http://dev.eclipse.org/newslists/news.eclipse.birt/msg18377. html
Etienne
Re: RCP, scripted datasource and classpath [message #254130 is a reply to message #253937] Sat, 01 September 2007 19:40 Go to previous messageGo to next message
surya wrote:
> Hello Mike,
> report as scripted data source in the same eclipse project.
> 1. u can ste this property before staritng the platform // Option 1
> System.setProperty
> or
> 2.
> // Option - MyClass dSrc = new MyClass();
> so u can use theoption that i have given below:
> this. You can set this for the task or the engine like:
> resolved
> Thanks and Regards
> Surya
Thanks option2 seems to work fine :).
In option 1 you say that I should set the classpath before the platform
starts up, where would I do that? I tried adding the code to teh
Activator but that didn't work for me.
Addd this to the Activator:
System.setProperty(EngineConstants.WEBAPP_CLASSPATH_KEY,
System.getProperty("java.class.path"));
Many thanks,
Mike
Re: RCP, scripted datasource and classpath [message #254180 is a reply to message #254130] Mon, 03 September 2007 01:58 Go to previous message
Hello..
the system property shd be set before starting the BIRT platform when all
the pluggins are loaded..
I mean to say when u say
platform.startup(config);
Furthur the path shd be the location of the custom class files or jar
files which u wud be accessing in ur Java Script code..
e.g if i have created a sample java class DataSource.java in the same
directory as the ExecutreReport.java . then the class path i wud be giving
as "./bin" as after building all the class files for default package wud
be put into bin directory
surya
Previous Topic:What's happened to propertyPage and IReportItemPropertyEditUI
Next Topic:DataSetEventHandler and ClassNotFoundException
Current Time: Sun Sep 28 14:54:45 EDT 2025
Powered by FUDForum. Page generated in 0.04728 seconds
