Home » Newcomers » Newcomers » Programmatically create popup
Programmatically create popup [message #253838] Mon, 14 April 2008 07:25 Go to next message
Originally posted by: andymorton.btinternet.com
I have a popup menu via a plugin extension.
I want to do some processing and add items to this menu whenever the
plugin runs / activates.
Is this possible? I only want to have the top level menu in the
plugin.xml, just to be a container...
All ideas welcome!
Andrew
Re: Programmatically create popup [message #253897 is a reply to message #253838] Mon, 14 April 2008 16:26 Go to previous message
You'll need code along the lines of:
MenuManager menuMgr = new MenuManager("#PopupMenu");
menuMgr.add(new GroupMarker(IWorkbenchActionConstants.MB_ADDITIONS));
viewer.getControl().setMenu(menu);
getSite().registerContextMenu(menuMgr, viewer);
That last line is important. Check out the comments on
registerContextMenu.
Also, read this:
http://www.eclipse.org/articles/article.php?file=Article-act ion-contribution/index.html
HTH,
Wayne
On Mon, 2008-04-14 at 11:25 +0000, Andrew Morton wrote:
> All ideas welcome!
> Andrew
Previous Topic:How to verify that WebTools Platform is successfully installed?
Next Topic:show part of a bitmap
Current Time: Mon Nov 03 09:43:33 EST 2025
Powered by FUDForum. Page generated in 0.08578 seconds
