Home » Newcomers » Newcomers » Formula Fields
Formula Fields [message #253767] Fri, 11 April 2008 13:24 Go to next message
Originally posted by: lholt.ucsd.edu
I am new to Birt Reporting, and I need help in finding out how to create a
value/expression.
In crystal report it's setup this way:
Local StringVar Record := "";
Record := (Left ({table.record},2));
Record;
What syntax do I need to set this up in birt.
Lura
Re: Formula Fields [message #253813 is a reply to message #253767] Sat, 12 April 2008 21:10 Go to previous messageGo to next message
Lura wrote:
> Hello,
> a value/expression.
> Record;
> Lura
Hi Lura. I think you'll have better luck at the eclipse.birt forum. I've
copied this reply to that forum for you. Mark
Re: Formula Fields [message #253880 is a reply to message #253813] Mon, 14 April 2008 11:56 Go to previous message
Try
dataSetRow["PRODUCTCODE"].substr(0,2)
Jason
Mark Dexter wrote:
> Lura wrote:
>> Hello,
>> create a value/expression.
>> Record;
>> Thanks,
>> Lura
Previous Topic:Default run target, desired run behavior
Next Topic:Eclipse crash on start-up
Current Time: Wed Nov 05 05:35:53 EST 2025
Powered by FUDForum. Page generated in 0.09750 seconds
