RC3 wont start on Ubuntu: XPCOM Mozilla error [message #253677] |
Mon, 02 June 2008 11:21  |
I downloaded the Eclipse SDK 3.4RC3, running it goes like this:
- Asks for workspace
- I press OK
- Shows Splash
- Splash closes
- An empty popup, title "Eclipse".
The first stack entry in the log is an XPCOM error, after that I get a
lot of "Widget exposed too early" errors (see below). I wonder where
that comes from. I set up the box a few days ago with Ubuntu 8.04. It
ships by default with a Firefox 3 Beta, maybe this is causing troubles?
Running RC1 doesnt give me that problem.
!ENTRY org.eclipse.osgi 4 0 2008-06-02 17:16:51.831
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: XPCOM error -2147467262
at org.eclipse.swt.browser.Mozilla.error(Mozilla.java:1597)
at org.eclipse.swt.browser.Mozilla.setText(Mozilla.java:1820)
at org.eclipse.swt.browser.Browser.setText(Browser.java:733)
org.eclipse.ui.internal.intro.impl.presentations.BrowserIntr oPartImplementation.generateContentForPage(BrowserIntroPartI mplementation.java:252)
org.eclipse.ui.internal.intro.impl.presentations.BrowserIntr oPartImplementation.dynamicStandbyStateChanged(BrowserIntroP artImplementation.java:451)
org.eclipse.ui.internal.intro.impl.presentations.BrowserIntr oPartImplementation.doStandbyStateChanged(BrowserIntroPartIm plementation.java:658)
org.eclipse.ui.internal.intro.impl.model.AbstractIntroPartIm plementation.standbyStateChanged(AbstractIntroPartImplementa tion.java:249)
org.eclipse.ui.internal.intro.impl.model.IntroPartPresentati on.standbyStateChanged(IntroPartPresentation.java:443)
org.eclipse.ui.intro.config.CustomizableIntroPart.standbySta teChanged(CustomizableIntroPart.java:266)
org.eclipse.ui.internal.ViewIntroAdapterPart$2.run(ViewIntro AdapterPart.java:74)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.ViewIntroAdapterPart.setStandby(View IntroAdapterPart.java:70)
org.eclipse.ui.internal.ViewIntroAdapterPart$1.propertyChang ed(ViewIntroAdapterPart.java:55)
org.eclipse.ui.internal.WorkbenchPartReference.fireInternalP ropertyChange(WorkbenchPartReference.java:374)
org.eclipse.ui.internal.WorkbenchPartReference.fireZoomChang e(WorkbenchPartReference.java:539)
at org.eclipse.ui.internal.PartPane.setZoomed(PartPane.java:349 )
at org.eclipse.ui.internal.PartStack.setZoomed(PartStack.java:1 526)
org.eclipse.ui.internal.PartSashContainer.zoomIn(PartSashCon tainer.java:884)
org.eclipse.ui.internal.PartSashContainer.childRequestZoomIn (PartSashContainer.java:905)
at org.eclipse.ui.internal.LayoutPart.requestZoomIn(LayoutPart. java:354)
at org.eclipse.ui.internal.PartStack.setState(PartStack.java:15 01)
at org.eclipse.ui.internal.WorkbenchPage.setState(WorkbenchPage .java:3872)
org.eclipse.ui.internal.WorkbenchPage.toggleZoom(WorkbenchPa ge.java:3944)
org.eclipse.ui.internal.WorkbenchIntroManager.setIntroStandb y(WorkbenchIntroManager.java:201)
org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(Work benchIntroManager.java:136)
org.eclipse.ui.application.WorkbenchWindowAdvisor.openIntro( WorkbenchWindowAdvisor.java:173)
org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAd visor.openIntro(IDEWorkbenchWindowAdvisor.java:458)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:777)
org.eclipse.ui.internal.Workbench$22.runWithException(Workbe nch.java:1041)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:132)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3375)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3033)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1361)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:112)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
!ENTRY org.eclipse.ui.workbench 4 0 2008-06-02 17:16:51.784
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDispo sed(WorkbenchPartReference.java:171)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:116)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1154)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1178)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1159)
at org.eclipse.swt.widgets.Widget.release(Widget.java:1023)
at org.eclipse.swt.widgets.Control.release(Control.java:3164)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite. java:1182)
at org.eclipse.swt.widgets.Widget.release(Widget.java:1026)
at org.eclipse.swt.widgets.Canvas.releaseChildren(Canvas.java:1 96)
org.eclipse.swt.widgets.Decorations.releaseChildren(Decorati ons.java:465)
at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:186 1)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:440)
at org.eclipse.swt.widgets.Shell.dispose(Shell.java:1806)
at org.eclipse.swt.widgets.Display.release(Display.java:3080)
at org.eclipse.swt.graphics.Device.dispose(Device.java:235)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:128)
FUDForum. Page generated in 0.05893 seconds
