Home » Archived » BIRT » How do I rotate text
How do I rotate text [message #253519] Mon, 27 August 2007 07:40 Go to next message
I designed a grid with a lot of columns. The Labels I need to put as
column headers are all long words which means I won't be able to create a
decent layout. Is there any possibility to rotate text by 90 degrees? I
did not find any solution, but I hope there is someone out there to help
me solve this (everyday) problem.
Re: How do I rotate text [message #253812 is a reply to message #253519] Wed, 29 August 2007 03:33 Go to previous messageGo to next message
Well, I found org.eclipse.birt.sample.reportitem.rotatedtext.jar, but I
cannot use it. I moved it to the plugins folder and startet eclipse
-clean, but it doesn't show up. Any ideas?
Re: How do I rotate text [message #253854 is a reply to message #253812] Wed, 29 August 2007 10:06 Go to previous messageGo to next message
Christian,
I believe the dev team is still working on that example.
Jason
Re: How do I rotate text [message #253918 is a reply to message #253854] Wed, 29 August 2007 20:29 Go to previous messageGo to next message
Christian,
There is a similar, but working example
org.eclipse.birt.sample.reportitem.rotatedlabel in Integrating and
extending BIRT book. The book has a detailed explanation how to create the
plugin and how to rotate the text. It comes with the source code as well.
The book implementation is with version 2.1. There will be a new edition
of the book published for BIRT 2.2.
Iana
Re: How do I rotate text [message #254208 is a reply to message #253918] Mon, 03 September 2007 06:11 Go to previous message
Thanks for the Message, I already own the book, but I am having a hard
time programming it by myself, that's why I hoped to find the working
plugin somewhere....
Previous Topic:Birt and Vista - Excpetion?
Next Topic:EJB Datasource & jndi.properties
Current Time: Tue Nov 04 08:41:17 EST 2025
Powered by FUDForum. Page generated in 0.05024 seconds
