Home » Newcomers » Newcomers » Help needed in Silent Installation
Help needed in Silent Installation [message #253359] Mon, 07 April 2008 13:38 Go to next message
Originally posted by: upendra249.gmail.com
Hello Everyone:
This is Upendra. I recently downloaded eclipse sdk 3.2.1 on Windows-XP. I
want to install eclipse in silent mode/non-interactive mode. Can anyone
please tell me how can I do that??
Thanks so much.
Best Regards,
-Upen-
Re: Help needed in Silent Installation [message #253373 is a reply to message #253359] Mon, 07 April 2008 16:17 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Upen" <upendra249@gmail.com> wrote in message
news:5c668e4e4f30839fd3e57ece00f14748$1@www.eclipse.org...
> Hello Everyone:
Upendra, I'm not sure why, if you're installing now, you would use 3.2.1;
why not a more recent version, such as 3.3.2? 3.2.1 is more than a year old
and is missing a lot of bug fixes and feature improvements.
Ignoring that: Eclipse does not have an install program; you just unzip the
archive to whatever directory you want. So if your unzip tool has a silent
mode, that's what you would use. How to use it, of course, depends on what
unzip tool you are using.
Or are you asking something different than that?
Re: Help needed in Silent Installation [message #253375 is a reply to message #253373] Mon, 07 April 2008 16:42 Go to previous messageGo to next message
Dear Harley thanks for replyIng..After unzipping the archive I am running
the eclIpse.exe file which is asking me to enter a workspace
dIrectory...when I specify a path and click ok It Installs...and the IDE
opens
what I want Is when I click on the eclIpse.exe It should not ask me to
enter any path for workspace directory or anything...It should create a
workspace directory on its own.....please let me know If I am clear
Re: Help needed in Silent Installation [message #253379 is a reply to message #253373] Mon, 07 April 2008 16:43 Go to previous messageGo to next message
opens
Re: Help needed in Silent Installation [message #253382 is a reply to message #253379] Mon, 07 April 2008 16:59 Go to previous messageGo to next message
> running the eclIpse.exe file which is asking me to enter a workspace
> opens
In that dialog, there is a checkbox that you can use to tell it not to
ask you again.
By the way, this is not "installation" of Eclipse - it is asking you
what workspace you want to use for this session. You should read the
help contents and learn about how Eclipse works, including workspaces.
Hope this helps,
Eric
Re: Help needed in Silent Installation [message #253477 is a reply to message #253382] Tue, 08 April 2008 09:57 Go to previous messageGo to next message
Eric thanks for the reply...I have got a quick question...what should be
done to make eclipse take a default workspace directory instead of me
giving it manually, everytime I run the .exe files.
My actual question was...what should be done to make eclipse do everything
by itself without any user interaction?? The user only double clicks the
eclipse.exe file and the user will not specify any workspace directory
path, instead everything will be done by eclipse only.
Any inputs will be helpful...
Re: Help needed in Silent Installation [message #253481 is a reply to message #253477] Tue, 08 April 2008 10:33 Go to previous messageGo to next message
On Tue, 8 Apr 2008 13:57:26 +0000 (UTC), upendra249@gmail.com (Upen)
>Thanks
See
http://help.eclipse.org/help32/topic/org.eclipse.platform.do c.user/tasks/running_eclipse.htm
in the section about selecting a workspace directory by modifiying the
eclipse.ini file (described for a Mac, but this will work on every
platform).
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/career/eclipse.html
Re: Help needed in Silent Installation [message #253505 is a reply to message #253477] Tue, 08 April 2008 12:41 Go to previous messageGo to next message
news:7fb5608c7cddc10ed94bd9887926399b$1@www.eclipse.org...
Upen, I think we're having trouble understanding what you mean by "make
Eclipse do everything by itself." Eclipse is an IDE - it's a tool for
humans to edit and work with code. It doesn't do anything at all by itself.
Are you looking for a scripting solution, to drive Eclipse's functionality
from a script? I don't think that exists yet, but I know there are some
people working on it, so you could look into it with Google if that's what
you're interested in. Or are you looking for a way to do automated builds
of an existing workspace? For that, you either want to export Ant scripts
from the projects and run them from the command line, or you may want to run
a "headless" Eclipse (again, you can Google for that term to learn more).
If it's neither of those things, you need to explain better.
Re: Help needed in Silent Installation [message #253509 is a reply to message #253481] Tue, 08 April 2008 13:18 Go to previous messageGo to next message
Achim..thanks for the reply...but what modifications should be made to the
eclipse.ini file??? its not mentioned in the linked you gave me...
Re: Help needed in Silent Installation [message #253521 is a reply to message #253505] Tue, 08 April 2008 16:40 Go to previous messageGo to next message
Harley...I want to execute the eclipse.exe from command prompt. My OS is
windows XP. In the command prompt I can go to the directory where the
eclipse.exe is located and run it.
For Example my eclipse.exe is in eclipse which is in C:\ drive. So to
execute it, I will type this in command prompt:
c:\eclipse\eclipse.exe
Now the eclipse splash screen opens and asks me to enter a work space
directory.Here I dont want to give any path, instead eclipse by default
should take its own path. This is the only thing I had been asking.
So what should I do to make it possible. If understood, Please let me know
what can be done. Let me know if I am clear.
Thanks for the help.
Re: Help needed in Silent Installation [message #253533 is a reply to message #253521] Tue, 08 April 2008 19:48 Go to previous messageGo to next message
Googling "eclipse command line switches" brings Eclipse Runtime Options
at the top of the list
c:\eclipse\eclipse -data c:\myworkspace
> know what can be done. Let me know if I am clear.
Re: Help needed in Silent Installation [message #253541 is a reply to message #253509] Tue, 08 April 2008 21:21 Go to previous messageGo to next message
news:95c2af4b672c3bcd8e33389b14459ccb$1@www.eclipse.org...
Use the -data command line switch, but put it in the .ini file (if you don't
want to specify a command line).
It looks like there may have been a bad edit in the wiki at some point; the
topic on specifying a workspace seems to be truncated and runs directly into
the section on specifying a VM, which is missing its topic header.
Re: Help needed in Silent Installation [message #253604 is a reply to message #253541] Wed, 09 April 2008 17:29 Go to previous messageGo to next message
Well, did you correct it?
Eric
Re: Help needed in Silent Installation [message #253608 is a reply to message #253604] Wed, 09 April 2008 18:21 Go to previous message
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:ftjcec$k1d$3@build.eclipse.org...
My bad, it's a help topic, not a wiki. (It's also in the readme.) I've
entered https://bugs.eclipse.org/bugs/show_bug.cgi?id=226384 with a proposed
patch.
Previous Topic:Ecllipse C/C++ and Vista, problem
Next Topic:Spring release for Eclipse IDE for Java EE Developers
Current Time: Fri Nov 07 09:39:15 EST 2025
Powered by FUDForum. Page generated in 0.10828 seconds
