Home » Language IDEs » Java Development Tools (JDT) » Using ASTParser with binding resolving in a standalone application
Using ASTParser with binding resolving in a standalone application [message #253189] Tue, 06 May 2008 05:28 Go to next message
Hello all
I have written a plugin that does some AST Parsing with binding
resolving. Now I need to do the same outside of eclipse, in a standalone
application.
To have binding resolving, I need a configured project (as far as I
understood). To have a project, I need a workspace.
I have found a lot of snippets on how to create a project inside a
plugin. But how do I:
1. create a new workspace <-- how to do that
2. set up a new project
3. add the files (jars, java sources, ...)
4. Perform some AST analyzing
5. shut down the project and workspace
6. delete the complete workspace with the project
The question now is: How do I programmatically create a new workspace
from scratch?
Something like "ResourcesPlugin.getPlugin().start(BundleContext?);"?
Steps 2 to 4 are ok. 5 and 6 should be intuitive once knowing step 1.
Any help? Hints? Similar applications/snippets? Is it even possible?
Or is there an easier way of getting the bindings? I am able to do some
AST parsing without binding resolving in my standalone application by
providing the source as char[].
thanks
Marco
Re: Using ASTParser with binding resolving in a standalone application [message #253270 is a reply to message #253189] Tue, 13 May 2008 03:26 Go to previous messageGo to next message
"Marco Trudel" <marco@mtsystems.ch> wrote in message
news:fvp8ct$7sq$1@build.eclipse.org...
> The question now is: How do I programmatically create a new workspace from
> scratch?
You might want to take a look at the JDT Builder test plug-in (which you can
get from CVS). The JDT tests have to do just what you're describing.
Sorry, I don't have a workspace open right now so I can't give you the exact
class to look at.
Re: Using ASTParser with binding resolving in a standalone application [message #253331 is a reply to message #253270] Tue, 13 May 2008 15:31 Go to previous messageGo to next message
>> scratch?
> get from CVS).
Thanks for your answer. I now checked out
org.eclipse.jdt.core.tests.builder. Is this the correct directory?
I looked at the source files but didn't find a the code to create a
workspace from scratch (only the usual ResourcesPlugin.getWorkspace()).
But of course I might have missed it (or got the wrong directory).
> class to look at.
A snippet for what I have to look for or, if I got the wrong directory,
the correct one would be great.
Thanks for your time
Marco
Re: Using ASTParser with binding resolving in a standalone application [message #253336 is a reply to message #253331] Tue, 13 May 2008 20:08 Go to previous messageGo to next message
news:4829EC8E.4030706@mtsystems.ch...
Ah, yes, you're correct. I'm starting to get a clearer picture of what
you're trying to do, and unfortunately I don't think you can do it. If I
understand, you're hoping to use the classes in org.eclipse.jdt.core.dom,
outside of the context of an Eclipse executable. I'm not an expert, but I
don't believe that's possible. The DOM AST classes have dependencies on
classes (e.g., IPath) that are defined by the Eclipse runtime. I think if
it is working at all right now you might just be getting lucky... Is there
some reason that this has to be a standalone application?
Re: Using ASTParser with binding resolving in a standalone application [message #253350 is a reply to message #253336] Wed, 14 May 2008 03:53 Go to previous message
Well, Eclipse is doing it, so there's no logical reason why I couldn't
do it. The only question is how and how hard it will get.
> If I
Exactly. Simple AST parsing without binding resolving of Java source
files as char[] works perfectly. These jars are needed in order to make
this work outside the Eclipse context:
- org.eclipse.core.contenttype_3.2.100.v20070319.jar
- org.eclipse.core.jobs_3.3.1.R33x_v20070709.jar
- org.eclipse.core.resources_3.3.1.R33x_v20080205.jar
- org.eclipse.core.runtime_3.3.100.v20070530.jar
- org.eclipse.equinox.common_3.3.0.v20070426.jar
- org.eclipse.equinox.preferences_3.2.101.R33x_v20080117.jar
- org.eclipse.jdt.core_3.3.3.v_793_R33x.jar
- org.eclipse.osgi_3.3.2.R33x_v20080105.jar
AST parsing is straight forward. I don't think it's luck that it works.
But as soon as binding resolving comes into the game, it gets harder and
a real Eclipse project is needed (probably on a PC of a enduser that
does not have Eclipse installed).
> Is there
Well, having an end-user application that does some AST processing is
nothing special nowadays. And since the eclipse AST parser is excellent,
it would be great to also have access to the bindings.
In my case, Java AST parsing is a little part of a large project that
doesn't fit into Eclipse.
thanks
Marco
Previous Topic:How to change debug highlighting color?
Next Topic:Compiler and multi-core
Current Time: Thu Nov 06 07:16:13 EST 2025
Powered by FUDForum. Page generated in 0.04186 seconds
