Home » Archived » BIRT » Birt and Vista - Excpetion?
Birt and Vista - Excpetion? [message #253166] Tue, 21 August 2007 16:42 Go to next message
Originally posted by: calmacroi.myrddin.ch
hi
i'm testing our software which uses still birt 2.0.1 on vista
environment with XML data source as inputsream
now on vista it generates following exception:
Aug 21 15:40:14 SEVERE
ch.spf.PS4Gui.Report.ReportGenerator:prepareRendering -->OdaException on
opening input stream:
org.eclipse.datatools.connectivity.oda.OdaException: Access denied@
org.eclipse.birt.report.data.oda.xml.util.XMLDataInputStream . <init>(XMLDataInputStream.java:61)
ch.spf.PS4Gui.Report.ReportGenerator.prepareRendering(null:- 1)
and here the code which generates the exception:
private void prepareRendering(Image aVariantImage, ImageIcon
aProjectImageIcon, IReportRunnable design) {
mTask = mEngine.createRunAndRenderTask(design);
HashMap contextMap = new HashMap();
FileInputStream fis = null;
try {
fis = new FileInputStream(PS4Gui.getPathReports() +
REPORT_DATA_FILE_OUTPUT_NAME);
XMLDataInputStream xmlStream = new XMLDataInputStream(fis);
contextMap.put("org.eclipse.birt.report.data.oda.xml.inputStream ",
xmlStream);
contextMap.put("org.eclipse.birt.report.data.oda.xml.closeInputStream ",
new Boolean(true));
} catch (FileNotFoundException fex) {
sLog.severe("InputStream File not found: " +
Swinger.getStackTraceString(fex));
} catch (OdaException odaEx) {
sLog.severe("OdaException on opening input stream: " +
Swinger.getStackTraceString(odaEx));
is that cause of the vista environment, because i'm not sure if birt
supports vista yet?
i'm very grateful on any help
thanks
patrick
Re: Birt and Vista - Excpetion? [message #253301 is a reply to message #253166] Thu, 23 August 2007 04:26 Go to previous messageGo to next message
From BIRT2.2.0, Vista is supported.
Please try latest build.
"Patrick" <calmacroi@myrddin.ch> wrote in message
news:fafink$emv$1@build.eclipse.org...
> hi
> i'm testing our software which uses still birt 2.0.1 on vista environment
> opening input stream: org.eclipse.datatools.connectivity.oda.OdaException:
> Access denied@
> try {
> xmlStream);
> new Boolean(true));
> supports vista yet?
> thanks
> patrick
Re: Birt and Vista - Excpetion? [message #253311 is a reply to message #253301] Thu, 23 August 2007 09:58 Go to previous messageGo to next message
hi ichen
thanks for your reply
the problem is, that all has changed in birt 2.1.2 compared to 2.0.1
(structure etc.) and we use it within a desktop application with update
possibility, so its a big invest to update birt yet.
probably it is neccessary to update but i do not understand why birt
2.0.1 should not support vista - because it runs not directly on the os
- it talks just to the JVM
cheers
patrick
>> hi
>> Access denied@
>> try {
>> xmlStream);
>> new Boolean(true));
>> supports vista yet?
>> thanks
>> patrick
Re: Birt and Vista - Excpetion? [message #254204 is a reply to message #253311] Mon, 03 September 2007 06:03 Go to previous message
Please submit a bug in bugzilla to require this support, thanks.
news:fak3qj$tuu$1@build.eclipse.org...
> hi ichen
> probably it is neccessary to update but i do not understand why birt 2.0.1
> should not support vista - because it runs not directly on the os - it
> cheers
> patrick
>>> hi
>>> try {
>>> xmlStream);
>>> new Boolean(true));
>>> supports vista yet?
>>> thanks
>>> patrick
Previous Topic:DataSetEventHandler and ClassNotFoundException
Next Topic:How do I rotate text
Current Time: Sun Jul 27 08:47:20 EDT 2025
Powered by FUDForum. Page generated in 0.03826 seconds
