Home » Language IDEs » Java Development Tools (JDT) » On ASTParser:May I parser only part of the file
On ASTParser:May I parser only part of the file [message #253030] Mon, 28 April 2008 08:19 Go to next message
Originally posted by: reg.zhuce.163.com
May I set the Root of ASTNode to parser by location,say,offset and length?
I only want to parser a line of code.I think I can use ASTVisitor,but
ASTVisitor seems to start at the very beginning of the CompilationUnit
every time.
Any suggestions?
Re: On ASTParser:May I parser only part of the file [message #253066 is a reply to message #253030] Tue, 29 April 2008 08:25 Go to previous messageGo to next message
> every time.
> Any suggestions?
You can use ASTParser.setFocalPosition(..).
This will however scan all statements within a method.
If you want to use this method, you should take the upcoming 3.4M7
build. Two issues have been fixed with this method.
Olivier
Re: On ASTParser:May I parser only part of the file [message #253078 is a reply to message #253066] Tue, 29 April 2008 10:02 Go to previous messageGo to next message
What does setSourceRange(..) mean?
Is it relative to this problem?
Olivier Thomann 写道:
>> every time.
>> Any suggestions?
> Olivier
Re: On ASTParser:May I parser only part of the file [message #253103 is a reply to message #253078] Tue, 29 April 2008 17:02 Go to previous message
No, setSourceRange(...) is called for you by the parser.
Olivier
Previous Topic:Hide/disable Package Explorer actions?
Next Topic:RunnableJar Feature in 3.4M4
Current Time: Sun Aug 31 08:00:11 EDT 2025
Powered by FUDForum. Page generated in 0.04618 seconds
