Home » Language IDEs » Java Development Tools (JDT) » e3.5 & e4 - Is it about time Eclipse compiler fixed bugs that Sun hasn't?
e3.5 & e4 - Is it about time Eclipse compiler fixed bugs that Sun hasn't? [message #252618] Thu, 10 April 2008 18:20 Go to next message
In bugs https://bugs.eclipse.org/bugs/show_bug.cgi?id=158870 and
https://bugs.eclipse.org/bugs/show_bug.cgi?id=99107, we have closed,
*not fixed*, compiler bugs that correspond to bugs that Sun has had "In
progress" since 2005.
These, in particular relate to bugs where an error is given on a generic
cast, but the assignment can be valid, and should therefore get an
"unchecked conversion" warning, as the types are not "provably distinct"
as, it seems is the wording of the JLS (see bottom of
http://bugs.sun.com/view_bug.do?bug_id=6557279).
an example is:
Iterator<Enum<?>> it = null;
Iterator<Enum> error = (Iterator<Enum>)it;
which gives an error, while the following, which has the same erased
types doe work, with the appropriate warning:
Iterator<Enum> error = (Iterator)it;
As a user of Eclipse, I want to benefit from generics, and be able to
work with legacy classes.
Therefore, the question I've got for those who'll discuss it, is:
Should Eclipse continue to re-implement Sun's bugs, or should there be a
distinct policy change for e4 or even for e3.5?
When all is said and done, these bugs can be just another checkbox in
the "Errors/Warnings" preference page, defaulting to "Error", with a
Quick-fix to change the preference for the project to "Warning".
Re: e3.5 & e4 - Is it about time Eclipse compiler fixed bugs that Sun hasn't? [message #252622 is a reply to message #252618] Thu, 10 April 2008 21:30 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Neale" <neale@nealeupstone.com> wrote in message
news:ftm3qh$alo$1@build.eclipse.org...
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=99107, we have closed, *not
> an example is:
> which gives an error, while the following, which has the same erased types
> As a user of Eclipse, I want to benefit from generics, and be able to work
> When all is said and done, these bugs can be just another checkbox in the
> "Errors/Warnings" preference page, defaulting to "Error", with a Quick-fix
Interesting discussion topic. I would submit three points to the
discussion:
1. Some companies base commercial products on Eclipse, and license the Java
trademark; for instance, IBM and BEA both sell Java compilers. These
companies need to run, and pass, the Java Certification Kit (JCK) to get the
license. In some cases, the JCK tests rely on Sun Java bugs. This is
obviously bogus, but it is true and sometimes difficult to work around. I
don't know whether that explains this particular case or not.
2. Sometimes it is not easy to fix a subtle compiler bug without major
changes to the compiler, which add the risk of other bugs. In the case of
an abstruse corner case, it may not be worth the effort. Again, not saying
that's the case here; you asked a general question.
3. Do you want your code to compile on Eclipse but not Sun? Keep in mind
that Eclipse-exported ant scripts run against javac, by default.
-Walter Harley
JDT APT
Re: e3.5 & e4 - Is it about time Eclipse compiler fixed bugs that Sun hasn't? [message #252628 is a reply to message #252618] Fri, 11 April 2008 05:15 Go to previous messageGo to next message
> an example is:
Neale,
As I explained to you in bug reports already, these are not javac bugs
we try to mimic but behaviors described by the Java language spec. Just
because javac happens to have bugs in this area as well, doesn't mean it
gets all cast semantics wrong. The javac bug you point at is a different
scenario which I admit is buggy.
To clarify, we do not try to mimic Javac bugs, we try to implement the
spec, even if at times the spec is fuzzy or has some inconsistencies. We
try to resolve them with spec masters, and provides the best behavior;
for the benefit of our Java users (as Walter observed, we do not want to
split our community of users).
If you can claim that the spec is wrong (argue with spec provider), and
win this fight, then we will adjust our semantics to whatever the spec
decides. In this very example, I believe the spec is accurate. Remember
that raw types have some limitations.
Sincerly,
Philippe
Re: e3.5 & e4 - Is it about time Eclipse compiler fixed bugs that Sun hasn't? [message #252631 is a reply to message #252622] Fri, 11 April 2008 05:38 Go to previous messageGo to next message
I completely agree here with you. That would be unacceptable IMHO.
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: e3.5 & e4 - Is it about time Eclipse compiler fixed bugs that Sun hasn't? [message #252657 is a reply to message #252628] Mon, 14 April 2008 15:45 Go to previous message
Philippe,
Thanks for pointing out that I gave a bad example. I ought not type
when tired.
I wouldn't know who to approach regarding the spec. I had a go at
trying to find JLS 5.5, which seemed to be referred to as the latest,
and failed.
So, the example I have given agrees with the JLS, which I'll have to
take your word on, not having the JLS or the in-depth knowledge.
This still doesn't answer the question of Eclipse fixing *bugs* that Sun
hasn't, rather than closing them.
I think that there is a case for the Eclipse compiler being both:
- the best implementation of the JLS
and
- with a JLS-deviation enabled, the best Java compiler available.
As an end user, I do not want a JLS compiler, I want a compiler that
gives me the most correct behaviour, with the ability to see warnings
where using Sun's compiler will give errors.
While, I can see the point that some people have made about
compatibility with the Sun compiler (although not Ant scripts: my
Luntbuild continuous integration sys is running the Eclipse compiler
using Eclise exported Ant files), this does not preclude having
behaviour that gives us end users more power.
Thanks for your tolerance,
Neale ;)
>> "In progress" since 2005.
>> generic cast, but the assignment can be valid, and should therefore
>> get an "unchecked conversion" warning, as the types are not "provably
>> distinct" as, it seems is the wording of the JLS (see bottom of
>> an example is:
>> a distinct policy change for e4 or even for e3.5?
> Neale,
> Sincerly,
> Philippe
Previous Topic:How use in a Folder without project
Next Topic:JDT JavaModelManager's workingCopyInfos map is out of sync
Current Time: Fri Nov 07 02:00:15 EST 2025
Powered by FUDForum. Page generated in 0.03656 seconds
