| How to retrieve an IReportContext from the API using a RunAndRenderTask? [message #252497] |
Wed, 15 August 2007 06:31  |
Originally posted by: Nobert.aol.com
I have to set a value using the
IReportContext.setPersistenGlobalVariable(..), but it seems not to be
possible to retrieve this object using the API. Due to project specific
reasons, I can not set the variable from within an internal script of the
report (e.g. "beforeOpen"), it has to be set from external using the API.
Several days of exploring the source gave no reasonable result...
Any help will be highly appreciated
Norbert
| Re: How to retrieve an IReportContext from the API using a RunAndRenderTask? [message #252713 is a reply to message #252583] |
Thu, 16 August 2007 04:13  |
Yes I've checked that, but it did'nt work in this way.
Those values were set according to the "setGlobalVariable()" rule,
which is nice, but not "persistent" (what means, they are valid during
both "run" and "render" phase).
Sorry for the lack of information: I'm using the 2.2 API
A chance to access the IReportContext would help (and would be convienient
even for some other tasks...)
Norbert
"Der Spunk" <spunk_der@hotmail.com> schrieb im Newsbeitrag
news:f9vjdc$5oc$1@build.eclipse.org...
> Did you check the method IEngineTask.setAppContext(java.util.Map context)?
> You can provide arbitrary Java Objects to the task via the context map and
> read them in report scripts with
> "reportContext.getAppContext().get(yourKey);" and then set it as a
> persistent global variable (if this is still necessary).
> Spunk
> "Norbert" <Nobert@aol.com> schrieb im Newsbeitrag
> news:f9ukm4$snb$1@build.eclipse.org...
>> Norbert
FUDForum. Page generated in 0.28154 seconds
