Home » Archived » BIRT » Accessing POST data in Scripted Data Source
Accessing POST data in Scripted Data Source [message #252390] Tue, 14 August 2007 13:34 Go to next message
So I've come across a need to allow an XML string to be "sent" to the BIRT
runtime engine and be used as a datasource. Seems like it is not possible
using the current set of datasource types, so I thought perhaps a Scripted
Data Source would be possible.
Not being a Java programmer, I need some help in going the right direction.
I looked at the example of creating a new Java class for use as a new
Scripted Datasource and it seemed pretty straightforward. Guess my biggest
problem is how will I access the POST data in that class? Any other help you
can provide will be appreciated.
~Dave
Re: Accessing POST data in Scripted Data Source [message #252411 is a reply to message #252390] Tue, 14 August 2007 15:24 Go to previous messageGo to next message
Originally posted by: vencat.b.gmail.com
Create a report parameter with same name as the name you are posting from
web page and access this parameter in your scripted datasource open or any
method as params["YOURPARAM"]
"Dave Greco" <dgreco3917@yahoo.com> wrote in message
news:f9sp43$r46$1@build.eclipse.org...
> direction. I looked at the example of creating a new Java class for use as
> a new Scripted Datasource and it seemed pretty straightforward. Guess my
> biggest problem is how will I access the POST data in that class? Any
> other help you can provide will be appreciated.
> ~Dave
Re: Accessing POST data in Scripted Data Source [message #252579 is a reply to message #252411] Wed, 15 August 2007 15:10 Go to previous messageGo to next message
Thanks for the pointer, it got me going in the right direction. I've created
the scripted datasource and a Java class for doing the XML parsing. Works
fine on my desktop in the report designer. Now, where do I put it on the app
server (birt runtime)?
"venc" <vencat.b@gmail.com> wrote in message
news:f9svho$ee2$1@build.eclipse.org...
>> BIRT runtime engine and be used as a datasource. Seems like it is not
>> possible using the current set of datasource types, so I thought perhaps
>> a Scripted Data Source would be possible.
>> as a new Scripted Datasource and it seemed pretty straightforward. Guess
>> my biggest problem is how will I access the POST data in that class? Any
>> ~Dave
Re: Accessing POST data in Scripted Data Source [message #252794 is a reply to message #252579] Thu, 16 August 2007 13:36 Go to previous message
Figured it out. Had to create a JAR file of the Java class, and place in
birt.war/scriptlib
news:f9vj2l$344$1@build.eclipse.org...
> created the scripted datasource and a Java class for doing the XML
> parsing. Works fine on my desktop in the report designer. Now, where do I
> put it on the app server (birt runtime)?
>> any method as params["YOURPARAM"]
>>> ~Dave
Previous Topic:HELP: show only groups in the generated report
Next Topic:Deploying BIRT runtime as a part of other web app
Current Time: Thu Oct 16 00:02:10 EDT 2025
Powered by FUDForum. Page generated in 0.04117 seconds
