Home » Language IDEs » Java Development Tools (JDT) » Can't append the environment variables when launch from eclipse
Can't append the environment variables when launch from eclipse [message #252376] Wed, 02 April 2008 02:36
Eclipse launch and debug support to set your environment variables. I
added variable 'LD_LIBRARY_PATH' in that 'Environment' tab, and check
'Append environment to native environment'. However, I tried to print out
the 'LD_LIBRARY_PATH' by System.getenv("LD_LIBRARY_PATH"), I found my
value replace the native environment, NOT append to it.
My eclipse version is 3.4M5, it has same problem both Windows and Linux.
Does anybody meet similar issue? Is it an eclipse bug?
Previous Topic:Bracket Matching with comments
Next Topic:Get the class file (IClassFile) from the java file (ICompilationUnit).
Current Time: Mon Jul 21 21:59:50 EDT 2025
Powered by FUDForum. Page generated in 0.07601 seconds
