Home » Language IDEs » Java Development Tools (JDT) » Run project in Command Prompt
Run project in Command Prompt [message #252220] |
Tue, 25 March 2008 20:02  |
Originally posted by: luke42990.gmail.com
I am trying to develop java command line programs, and all goes well, but
I have one thing a cannot figure out.. That is, is there any way to have
eclipse compile and then run a project in a Command Prompt (I.E. cmd.exe
in windows)? I have seen nothing on the internet.
Any help greatly appreciated!!
~Luke
Re: Run project in Command Prompt [message #252236 is a reply to message #252232] |
Tue, 25 March 2008 20:52   |
Luke Cycon wrote:
> I have examined this, but that seems rather cumbersome. I was hoping to be
> able to use something like the run button to have eclipse automatically run
> the application. I am looking to use this in testing, therefore changing
> the code then exporting then running in another command prompt seems
> inefficient.
> Thanks for the help,
> Luke Cycon
> "Mark Dexter" <dextercowley@gmail.com> wrote in message
> news:fsc4il$429$2@build.eclipse.org...
>>> ~Luke
>> Hi Luke. A simple way to do it is to export your classes to a JAR file and
>> the run the JAR file at the command prompt (e.g., java -jar
>> myjarfile.jar). You can also execute class files from the command prompt,
>> exactly like you would do without Eclipse. Hope this helps. Mark
Why do you want to run the programs from the command prompt during the
development process? You can simulate any behavior you need from inside
Eclipse, including command line input/output and arguments. Mark
Re: Run project in Command Prompt [message #252241 is a reply to message #252236] |
Tue, 25 March 2008 21:40   |
Originally posted by: luke42990.aim.com
I am trying to use the System.console() class. This returns a null
reference error in the eclipse console. Any further help appreciated!
~Luke
news:fsc6q1$33d$1@build.eclipse.org...
>> be able to use something like the run button to have eclipse
>> automatically run the application. I am looking to use this in testing,
>> therefore changing the code then exporting then running in another
>> command prompt seems inefficient.
>> Luke Cycon
>>>> but I have one thing a cannot figure out.. That is, is there any way
>>>> to have eclipse compile and then run a project in a Command Prompt
>>>> (I.E. cmd.exe in windows)? I have seen nothing on the internet.
>>>> ~Luke
>>> and the run the JAR file at the command prompt (e.g., java -jar
>>> prompt, exactly like you would do without Eclipse. Hope this helps. Mark
Re: Run project in Command Prompt [message #252249 is a reply to message #252241] |
Tue, 25 March 2008 23:21   |
> ~Luke
>>> Luke Cycon
>>>>> ~Luke
Hi Luke. A Google search "system.console eclipse" yielded this article:
http://www.eclipsezone.com/eclipse/forums/t93685.rhtml. It looks like
you might be out of luck on this. You can vote for the bug, if you like.
Re: Run project in Command Prompt [message #252252 is a reply to message #252249] |
Wed, 26 March 2008 00:27  |
Yes, I have seen that article, looks like I am out of luck.... But do you
know and alternatives to System.Console.Readln that do not require scanners
etc?
If you happen to know one, this problem is a non-issue.
~Luke
news:fscfgv$hl9$1@build.eclipse.org...
>> Thanks,
>> ~Luke
>>>> to be able to use something like the run button to have eclipse
>>>> testing, therefore changing the code then exporting then running in
>>>> another command prompt seems inefficient.
>>>> Luke Cycon
>>>>>> ~Luke
>>>>> Mark
> http://www.eclipsezone.com/eclipse/forums/t93685.rhtml. It looks like you
> might be out of luck on this. You can vote for the bug, if you like. Hope
> this helps. Mark
Current Time: Wed Jul 23 18:06:58 EDT 2025
Powered by FUDForum. Page generated in 0.04879 seconds
