Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » capturing output of remote run process
capturing output of remote run process [message #24828] Tue, 03 June 2008 07:33 Go to next message
Hi All,
I am using eclipse 3.4M7 with 0.95RC2 DLTK and RSE-SDK-3.0RC1.
In my IDE,I am able to create a project in remote location (unix) with the
help of Remote System Explorer.
I am able to create scripts under that project in remote location. I have
set interpreter details of remote location and when I try to run the
script , it succesfully forms the command line and fires it. But I am not
getting any output in the console.
Is there any option to capture the output of the remote process and show
it in console?
Please Help.
regards,
Abhijit.
Re: capturing output of remote run process [message #24961 is a reply to message #24828] Tue, 03 June 2008 10:35 Go to previous messageGo to next message
Hi Abhijit,
> Hi All,
> the help of Remote System Explorer.
> have set interpreter details of remote location and when I try to run
> the script , it succesfully forms the command line and fires it. But I
> am not getting any output in the console.
> it in console?
Could you please be a bit more specific.
1) Do you use DLTK launching infrastructure? Or you have your own.
2) Does it not work only for Remote projects? And work for local.
3) Do you want to use standard eclipse input/output console, provided by debug plugin? Or you want your own console?
For standard consoles to be shown following value in launch configurations should be set
IDebugUIConstants.ATTR_CAPTURE_IN_CONSOLE to null.
You could check it from your LaunchConfigurationDelegate or AbstractScriptLaunchConfigurationDelegate based class, from
launch() method.
Andrei Sobolev.
Re: capturing output of remote run process [message #24982 is a reply to message #24961] Wed, 04 June 2008 04:27 Go to previous messageGo to next message
Hi Andrei,
Thank you for your help. I would reiterate our query to be more clear.
I have created my IDE for our domain language using DLTK framework (using
eclipse 3.4M7 with 0.95RC2 DLTK and RSE-SDK-3.0RC1.) We have referred ruby
IDE for the same.
-> 1) Do you use DLTK launching infrastructure? Or you have your own.
We are using DLTK launching infrastructure.
-> 2) Does it not work only for Remote projects? And work for local.
Yes.
I have created scripts under both local as well as remote projects. I have
set interpreter details for both locations (local and remote).
when I try to run the local script (in local project),it succesfully forms
the command line and fires it and shows the output in console of IDE. But
when I try to run the remote script (in remote project),it succesfully
forms the command line and fires it but does not show the output in
console of IDE. i.e. It shows the output in the console only for scripts
in local projects but not for scripts in Remote projects.
->3) Do you want to use standard eclipse input/output console, provided by
Yes, I want the output of scripts (for remote project) execution to be
displayed in standard console provided by DEbugPlugin.
I tried to set IDebugUIConstants.ATTR_CAPTURE_IN_CONSOLE to null in launch
method of LaunchConfigurationDelegate in following way :
launch.setAttribute(IDebugUIConstants.ATTR_CAPTURE_IN_CONSOL E, null);
Here launch is an object of ILaunch. But it doesn't work. Is this the
right way or am I doing it wrongly?
Please Help.
Thanks & regards,
Abhijit.
Re: capturing output of remote run process [message #25052 is a reply to message #24982] Thu, 05 June 2008 02:37 Go to previous messageGo to next message
Hi Abhijit,
I suppose what problem is not in console. But in remote execution.
Could you please try to debug RSEExecEnvironment.exec() method from org.eclipse.dltk.rse.core plugin.
This method is called on command execution for remote host. To check that is works, please add System.out.println() in
MyHostShellProcessAdapter.shellOutputChanged() method. All output from RSE execution are came here.
Do you use ssh or dstore connection? Does your remote host contain "bash"?
We called it as command interpreter. This unifies passing of environment variables, etc.
Andrei Sobolev.
> Hi Andrei,
> (using eclipse 3.4M7 with 0.95RC2 DLTK and RSE-SDK-3.0RC1.) We have
> referred ruby IDE for the same.
> Yes.
> have set interpreter details for both locations (local and remote).
> forms the command line and fires it and shows the output in console of
> IDE. But when I try to run the remote script (in remote project),it
> succesfully forms the command line and fires it but does not show the
> output in console of IDE. i.e. It shows the output in the console only
> for scripts in local projects but not for scripts in Remote projects.
> launch method of LaunchConfigurationDelegate in following way :
> Please Help.
> Thanks & regards,
> Abhijit.
Re: capturing output of remote run process [message #25340 is a reply to message #25052] Tue, 10 June 2008 00:29 Go to previous messageGo to next message
Hi Andrei,
I have done as you said i.e to put System.out.println() in
I have checked the output in the method and it is coming in the method.
However, in this method there is a for loop, inside which we are checking
"if (line.trim().equals(this.pattern1)) ". But in our case, when we log on
to unix terminal, we have to chose a module area and then command prompt
appear. Hence, there is a mismatch in the output. The pattern appears in
form "<command prompt>pattern1"; hence the equals method fails.
So in this case we changed the if statement to use endswith instead of
equals-"if (line.trim().endsWith(this.pattern1))". When we do this change,
the output appears in the console.
Can we somehow get a handle at this point to customise the method to
follow our logon procedure into unix terminal and then call
MyHostShellProcessAdapter.shellOutputChanged() so that the existing code
may work?
Thanks & regards,
Abhijit.
Re: capturing output of remote run process [message #25380 is a reply to message #25340] Tue, 10 June 2008 02:11 Go to previous messageGo to next message
Hi Abhijit,
We have fix in 0.95RC3, which uses endsWith() in this place.
Could you please check 0.95RC3.
Andrei Sobolev.
> Hi Andrei,
> checking "if (line.trim().equals(this.pattern1)) ". But in our case,
> when we log on to unix terminal, we have to chose a module area and then
> command prompt appear. Hence, there is a mismatch in the output. The
> pattern appears in form "<command prompt>pattern1"; hence the equals
> method fails.
> change, the output appears in the console.
> may work?
> Thanks & regards,
> Abhijit.
Re: capturing output of remote run process [message #25684 is a reply to message #25380] Fri, 13 June 2008 05:12 Go to previous messageGo to next message
Hi Andrei,
Thanks a lot for your responce. Now we are getting the output of remote
project in our console.
But now the output comes as command prompt (of unix) followed by required
output.
On going through the code we have observed that in the method
MyHostShellProcessAdapter.shellOutputChanged() we have the following code:
if (trimLine.endsWith(this.pattern1)) {
if (!trimLine.equals(this.pattern1)) {
// We need to output part of line
int pos = line.indexOf(this.pattern1);
outputStream.write(line.substring(0, pos).getBytes());
outputStream.write('\n');
outputStream.flush();
In the second if condition the line from 0 to pos is written to
outputstream. Hence the command prompt appears in output, which we don't
require. We want the output between the patterns only to be displayed.
Can we have the second if condition removed in the next release?
Please Help.
Re: capturing output of remote run process [message #25806 is a reply to message #25684] Sun, 15 June 2008 23:25 Go to previous messageGo to next message
Hi Abhijit,
> Hi Andrei,
> remote project in our console.
> required output.
Let's me explain why second if condition are required:
Lets use following script output:
%PATTERN%
Output line1
Output line2
Output line3%PATTERN%
There is no new line on end of output. Also this is happen then we have only one line with out new line symbol at end.
Without second if, we will receive no output.
Possibly solution for your case:
I suppose you could overwrite your command prompt passing environment variables PS1,PS2,PS4
With following values all output are fine:
PS1='\[\033[01;32m\]\u@\h\[\033[01;34m\] \w \$\[\033[00m\] '
PS2='> '
PS4='+ '
Also I suppose we could pass some default prompt from out code.
Thoughts?
Andrei Sobolev.
Re: capturing output of remote run process [message #25888 is a reply to message #25806] Mon, 16 June 2008 02:40 Go to previous messageGo to next message
--------------080607010305010601000300
Content-Type: text/plain; charset=UTF-8; format=flowed
What about the attached patch?
- the pattern is looked for only in the stdout lines (not stderr)
- the beginning of the line is written only if output is active
- skip is replaced with prefixCounter == 1
Alex
> %PATTERN%
> Output line1
> Output line2
> only one line with out new line symbol at end. Without second if, we
> PS2='> '
> PS4='+ '
> Thoughts?
> Best regards,
> Andrei Sobolev.
name="ShellProcessAdapter.patch"
Content-Disposition: inline;
filename="ShellProcessAdapter.patch"
IyMjIEVjbGlwc2UgV29ya3NwYWNlIFBhdGNoIDEuMA0KI1Agb3JnLmVjbGlw c2UuZGx0ay5y
c2UuY29yZQ0KSW5kZXg6IHNyYy9vcmcvZWNsaXBzZS9kbHRrL2NvcmUvaW50 ZXJuYWwvcnNl
L015SG9zdFNoZWxsUHJvY2Vzc0FkYXB0ZXIuamF2YQ0KPT09PT09PT09PT09 PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQ0KUkNTIGZp
bGU6IC9jdnNyb290L3RlY2hub2xvZ3kvb3JnLmVjbGlwc2UuZGx0ay9yc2Uv cGx1Z2lucy9v
cmcuZWNsaXBzZS5kbHRrLnJzZS5jb3JlL3NyYy9vcmcvZWNsaXBzZS9kbHRr L2NvcmUvaW50
ZXJuYWwvcnNlL015SG9zdFNoZWxsUHJvY2Vzc0FkYXB0ZXIuamF2YSx2DQpy ZXRyaWV2aW5n
IHJldmlzaW9uIDEuNg0KZGlmZiAtdSAtcjEuNiBNeUhvc3RTaGVsbFByb2Nl c3NBZGFwdGVy
LmphdmENCi0tLSBzcmMvb3JnL2VjbGlwc2UvZGx0ay9jb3JlL2ludGVybmFs L3JzZS9NeUhv
c3RTaGVsbFByb2Nlc3NBZGFwdGVyLmphdmEJMTEgSnVuIDIwMDggMDk6NTA6 MDEgLTAwMDAJ
MS42DQorKysgc3JjL29yZy9lY2xpcHNlL2RsdGsvY29yZS9pbnRlcm5hbC9y c2UvTXlIb3N0
U2hlbGxQcm9jZXNzQWRhcHRlci5qYXZhCTE2IEp1biAyMDA4IDA2OjM0OjUz IC0wMDAwDQpA
QCAtMTczLDcgKzE3Myw2IEBADQogCSAqICAgICAgc2hlbGxPdXRwdXRDaGFu Z2VkDQogCSAq
ICAgICAgKG9yZy5lY2xpcHNlLnJzZS5zZXJ2aWNlcy5zaGVsbHMuSUhvc3RT aGVsbENoYW5n
ZUV2ZW50KQ0KIAkgKi8NCi0JcHJpdmF0ZSBib29sZWFuIHNraXAgPSB0cnVl Ow0KIAlwcml2
YXRlIGludCBwcmVmaXhDb3VudGVyID0gMDsNCiANCiAJcHVibGljIHZvaWQg c2hlbGxPdXRw
dXRDaGFuZ2VkKElIb3N0U2hlbGxDaGFuZ2VFdmVudCBldmVudCkgew0KQEAg LTE4NiwyNiAr
MTg1LDI4IEBADQogCQkJCWlmIChsaW5lID09IG51bGwpIHsNCiAJCQkJCWNv bnRpbnVlOw0K
IAkJCQl9DQotCQkJCVN0cmluZyB0cmltTGluZSA9IGxpbmUudHJpbSgpOw0K LQkJCQlpZiAo
dHJpbUxpbmUuZW5kc1dpdGgodGhpcy5wYXR0ZXJuMSkpIHsNCi0JCQkJCWlm ICghdHJpbUxp
bmUuZXF1YWxzKHRoaXMucGF0dGVybjEpKSB7DQotCQkJCQkJLy8gV2UgbmVl ZCB0byBvdXRw
dXQgcGFydCBvZiBsaW5lDQotCQkJCQkJaW50IHBvcyA9IGxpbmUuaW5kZXhP Zih0aGlzLnBh
dHRlcm4xKTsNCi0JCQkJCQlvdXRwdXRTdHJlYW0ud3JpdGUobGluZS5zdWJz dHJpbmcoMCwg
cG9zKS5nZXRCeXRlcygpKTsNCi0JCQkJCQlvdXRwdXRTdHJlYW0ud3JpdGUo J1xuJyk7DQot
CQkJCQkJb3V0cHV0U3RyZWFtLmZsdXNoKCk7DQorCQkJCWlmICghZXZlbnQu aXNFcnJvcigp
KSB7DQorCQkJCQlTdHJpbmcgdHJpbUxpbmUgPSBsaW5lLnRyaW0oKTsNCisJ CQkJCWlmICh0
cmltTGluZS5lbmRzV2l0aCh0aGlzLnBhdHRlcm4xKSkgew0KKwkJCQkJCWlm IChwcmVmaXhD
b3VudGVyID09IDEgJiYgIXRyaW1MaW5lLmVxdWFscyhwYXR0ZXJuMSkpIHsN CisJCQkJCQkJ
Ly8gV2UgbmVlZCB0byBvdXRwdXQgcGFydCBvZiBsaW5lDQorCQkJCQkJCWlu dCBwb3MgPSBs
aW5lLmluZGV4T2YocGF0dGVybjEpOw0KKwkJCQkJCQlvdXRwdXRTdHJlYW0u d3JpdGUobGlu
ZS5zdWJzdHJpbmcoMCwgcG9zKQ0KKwkJCQkJCQkJCS5nZXRCeXRlcygpKTsN CisJCQkJCQkJ
b3V0cHV0U3RyZWFtLndyaXRlKCdcbicpOw0KKwkJCQkJCQlvdXRwdXRTdHJl YW0uZmx1c2go
KTsNCisJCQkJCQl9DQorCQkJCQkJcHJlZml4Q291bnRlcisrOw0KKwkJCQkJ CWlmIChwcmVm
aXhDb3VudGVyID09IDIpIHsNCisJCQkJCQkJLy8gU3lzdGVtLm91dC5wcmlu dGxuKCJDQUxM
IERFU1RST1kiKTsNCisJCQkJCQkJaG9zdFNoZWxsRXJyb3IuY2xvc2UoKTsN CisJCQkJCQkJ
aG9zdFNoZWxsSW5wdXQuY2xvc2UoKTsNCisJCQkJCQkJcmV0dXJuOw0KKwkJ CQkJCX0NCisJ
CQkJCQljb250aW51ZTsNCiAJCQkJCX0NCi0JCQkJCXByZWZpeENvdW50ZXIr KzsNCi0JCQkJ
CWlmIChwcmVmaXhDb3VudGVyID09IDIpIHsNCi0JCQkJCQkvLyBTeXN0ZW0u b3V0LnByaW50
bG4oIkNBTEwgREVTVFJPWSIpOw0KLQkJCQkJCWhvc3RTaGVsbEVycm9yLmNs b3NlKCk7DQot
CQkJCQkJaG9zdFNoZWxsSW5wdXQuY2xvc2UoKTsNCi0JCQkJCQlyZXR1cm47 DQotCQkJCQl9
DQotCQkJCQlza2lwID0gIXNraXA7DQotCQkJCQljb250aW51ZTsNCiAJCQkJ fQ0KLQkJCQlp
ZiAoIXNraXApIHsNCisJCQkJaWYgKHByZWZpeENvdW50ZXIgPT0gMSkgew0K IAkJCQkJb3V0
cHV0U3RyZWFtLndyaXRlKGxpbmUuZ2V0Qnl0ZXMoKSk7DQogCQkJCQlvdXRw dXRTdHJlYW0u
d3JpdGUoJ1xuJyk7DQogCQkJCQlvdXRwdXRTdHJlYW0uZmx1c2goKTsNCg==
--------------080607010305010601000300--
Re: capturing output of remote run process [message #25930 is a reply to message #25888] Mon, 16 June 2008 04:15 Go to previous messageGo to next message
Hi Alex,
Yes, this will help.
I've applied the patch.
Next build of 0.95 will contain this fix.
Andrei.
> Alex
>> %PATTERN%
>> Output line1
>> Output line2
>> have only one line with out new line symbol at end. Without second if,
>> PS2='> '
>> PS4='+ '
>> Thoughts?
>> Best regards,
>> Andrei Sobolev.
Re: capturing output of remote run process [message #26093 is a reply to message #25806] Tue, 17 June 2008 02:40 Go to previous message
hi Andrei,
There is one more possible solution. The second if condition shown below-
//code goes here
can be changed to - if ((prefixCounter == 1) &&
!trimLine.equals(this.pattern1)) {}
So that the second condition will be tested only for closing pattern and
not for opening.
Thanks & regards,
Abhijit.
Previous Topic:type hierarchy and code completion
Next Topic:ExtendedVariableReference and CallHolder vs. CallExpression and MethodCallExpression
Current Time: Sun Jun 15 07:37:58 EDT 2025
Powered by FUDForum. Page generated in 0.17405 seconds
