Home » Archived » Java WorkFlow Tooling (JWT) » [Metamodel] XPDL
[Metamodel] XPDL [message #24809] Thu, 08 March 2007 10:29 Go to next message
Hi all,
any points that we need to consider when adapting the meta-model regarding
XPDL? As we pointed out in former discussions we try to have a "Pivot
meta-model" which can be adapted to different representations and hence,
we don't simply take the XPDL metamodel. But it is necessary for our
further work to know the requirements that come within XPDL and that are
currently missing in the AgilPro (discussion) meta-model which can be seen
on our Wiki.
So, please can anybody summarize the requirements that XPDL has?
Thanks in advance,
Florian
Re: [Metamodel] XPDL [message #24950 is a reply to message #24809] Wed, 14 March 2007 12:37 Go to previous messageGo to next message
Hi Florian,
The only problem I can see here, is that there is several way of doing the
same thing in XPDL2.
For example you can invoke a web service directly from the activity (using
TaskService etc.) or you can use an application that define the web
service - and invoke an application from the task. And I believe most models
will have a few such cases (like what is the difference between BPMN's
Recieve Task and intermediate message event).
The question here is not how to translate XPDL into AgiPro, or other way
around, that is easy, both models seams to be capable to define and hold
process definition. But if we want to support roud-trip between those
models - so if we import and then export model it will look the same. This
include vendor specyfic extension that should be persisted.
Wojtek
"Florian Lautenbacher" <lautenbacher@informatik.uni-augsburg.de> wrote in
message news:4d936fd2a4b7c947f18ba78aa74f0ae9$1@www.eclipse.org...
> Hi all,
> on our Wiki.
> Thanks in advance,
> Florian
Re: [Metamodel] XPDL [message #25215 is a reply to message #24950] Mon, 19 March 2007 04:22 Go to previous message
Hi Wojtek,
I totally agree with you, that vendor specific extensions need to be
captured in the current model (and thats not an easy task!).
That one thing can be achieved using different ways is something that is
not a preferable solution in my eyes. I know that many standards include
different ways to do the same thing, but I can't see an advantage by
that. We should try to keep our meta-model simple and if we can generate
one of the ways using code generation it is enough - or what do you think?
I don't think that after importing and exporting a model it needs to
look the same as before, but the execution semantics must stay the same.
Florian
Wojciech Zurek schrieb:
> Hi Florian,
> Wojtek
>> Hi all,
>> on our Wiki.
>> Thanks in advance,
>> Florian
Previous Topic:[architecture] workgroup start
Next Topic:[Metamodel] Initial metamodel uploaded
Current Time: Sun Nov 09 01:54:06 EST 2025
Powered by FUDForum. Page generated in 0.03752 seconds
