Frustration in locating documentation [message #251684] |
Wed, 08 August 2007 10:56  |
Hi all,
I'm attempting to deploy BIRT to an MDB with a scripted data source that
retrieves an object, and then will use java callbacks to display the data
since our formatting is very specialized, and outside of the normal usage
of BIRT. Due to the need to set the BIRT home, deploying this to JBoss
has been problematic at best. I'm trying to create a Factory that will
load all the resources from the classpath, but I'm unable to find the
javadoc for version 2.2 anywhere. Can someone point me in the direction
of the technical doc?
Todd
Re: Frustration in locating documentation [message #251697 is a reply to message #251684] |
Wed, 08 August 2007 11:04  |
Todd,
The JavaDocs are available in the designer help.
If you are using the allinone just select the help->Help Contents.
The JavaDocs are in the BIRT Programmers Reference.
Jason
Todd Nine wrote:
> Hi all,
> that retrieves an object, and then will use java callbacks to display
> the data since our formatting is very specialized, and outside of the
> normal usage of BIRT. Due to the need to set the BIRT home, deploying
> this to JBoss has been problematic at best. I'm trying to create a
> Factory that will load all the resources from the classpath, but I'm
> unable to find the javadoc for version 2.2 anywhere. Can someone point
> me in the direction of the technical doc?
> Todd
FUDForum. Page generated in 0.10424 seconds
