Home » Newcomers » Newcomers » QuickFix Engine
QuickFix Engine [message #251604] Fri, 14 March 2008 11:25 Go to next message
Originally posted by: evega.onechicago.com
I have a Binary and a Source Project.
I dont know how to open them on Java Eclipse.
Can Someone Help me.
Re: QuickFix Engine [message #251607 is a reply to message #251604] Fri, 14 March 2008 11:55 Go to previous messageGo to next message
Edgar wrote:
> I have a Binary and a Source Project. I dont know how to open them on
> Java Eclipse.
> Thanks
Hi Edgar. You need to learn a little bit about projects in Eclipse. You
could start with the Java Development User Guide / Getting Started /
Basic Tutorial. Since you have existing source, you could look at
File/New Java Project and then select Create project from existing
source. Hope this helps. Mark
Re: QuickFix Engine [message #251626 is a reply to message #251607] Fri, 14 March 2008 14:55 Go to previous message
Originally posted by: edde_se.hotmail.com
If you've downloaded the source for one of the latest releases of
QuickFix/J (e.g 1.3.1) you actually get the source as a complete Eclipse
project. In Eclipse you simple select "File/Import/General/Existing
Projects Into Workspace". Then just select the "quickfixj" directory and
you're good to go.
/Eddie
Previous Topic:install Android Plugin
Next Topic:com.ibm cannot be resolved to a type
Current Time: Tue Nov 04 22:14:14 EST 2025
Powered by FUDForum. Page generated in 0.09672 seconds
