Convert a UML file to Ecore file [message #251455] |
Wed, 12 March 2008 16:40  |
I need to know how I can convert a UML file to ecore file. I use UML
modeling tool called Papyrus which creates two files: the first one
describe the graphical parts and the second one is the uml model. I use
Eclipse SDK 3.3.1.1 with Papyrus and mdt-uml2-SDK-2.1.1 plug-in it.
I can convert from Ecore to UML from "Sample Ecore Editor\Convert to
UML Model.." after I plug-in the "examples" from the UML project.
I tried to plug-in the package org.eclipse.uml2.uml.util which contains
UMLUtil.UML2EcoreConverter, but I couldn't find it.
Could you please help me. I would appreciate very much any information
that could help solve the problem.
Many thanks,
Rasha
Re: Convert a UML file to Ecore file [message #251495 is a reply to message #251485] |
Thu, 13 March 2008 10:02   |
Hi Ed and Rasha,
Converting a UML file to an Ecore file starts with the
ConvertToEcoreModelAction from the examples plugins.
You would need to select the root model element of your model (some subtype
of Package) then select
'UML Editor > Convert To... > Ecore Model'
You should then see an options dialog appear.
Hope that Helps.
- James.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:frb9dm$7q8$1@build.eclipse.org...
> Rasha,
> It's best to ask on the UML newsgroup, which I've added to the "to" list
> of the reply. Did you also install all the prerequisites for UML? I.e.,
> if you run with -clean -debug and look at the <workspace>/.metadata/.log
> or the Error log view, does it complain about missing dependencies?
> rasha wrote:
>> I can convert from Ecore to UML from "Sample Ecore Editor\Convert to UML
>> Many thanks,
>> Rasha
Re: Convert a UML file to Ecore file [message #251553 is a reply to message #251547] |
Thu, 13 March 2008 16:30   |
--------------080303000303030003020807
Rasha,
news://news.eclipse.org/eclipse.modeling.mdt.uml2
rasha wrote:
> Thanks Ed and James for your help. Ed, could you please send to me the
> contact info for the UML newsgroup, I couldn?t see it in the ?to? list.
> James, the problem that I couldn?t find the ?UML Editor?. I have the
> features UML2Examples and UML2ExamplesSource plugins. I have the
> SampleEcoreEdit but not the UML Edit. If you could know what I missed
> to install as prerequisites for UML, It?ll be highly appreciated.
> Cheers,
> Rasha
<html>
<head>
http-equiv="Content-Type">
</head>
Rasha,<br>
<blockquote><a href="news://news.eclipse.org/eclipse.modeling.mdt.uml2">news://news.eclipse.org/eclipse.modeling.mdt.uml2</a><br>
</blockquote>
<br>
<br>
rasha wrote:
<blockquote
cite="mid:a966c9a27f5468dbedf42deca65a44c4$1@www.eclipse.org"
type="cite">Thanks Ed and James for your help. Ed, could you please
send to me the contact info for the UML newsgroup, I couldn�t see it in
the �to� list.
<br>
<br>
James, the problem that I couldn�t find the �UML Editor�. I have the
to install as prerequisites for UML, It�ll be highly appreciated.
<br>
<br>
Cheers, <br>
Rasha
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------080303000303030003020807--
Re: Convert a UML file to Ecore file [message #251600 is a reply to message #251553] |
Fri, 14 March 2008 10:31   |
------=_NextPart_000_007B_01C885BE.81A00ED0
charset="ISO-8859-15"
You can download the entire SDK or runtime from here: =
http://www.eclipse.org/modeling/mdt/downloads/?project=3Duml 2
The prerequisites are also listed. Downloading the SDK for example =
would enable the menus you are looking for.
Or you can selectively choose the source code you want from cvs.
- James.
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:frc2st$va0$1@build.eclipse.org...
Rasha,
rasha wrote:=20
Thanks Ed and James for your help. Ed, could you please send to me =
the contact info for the UML newsgroup, I couldn?t see it in the ?to? =
list.=20
James, the problem that I couldn?t find the ?UML Editor?. I have the =
features UML2Examples and UML2ExamplesSource plugins. I have the =
SampleEcoreEdit but not the UML Edit. If you could know what I missed to =
install as prerequisites for UML, It?ll be highly appreciated.=20
Cheers,=20
Rasha=20
<HTML><HEAD>
content=3Dtext/html;charset=3DISO-8859-15>
<META content=3D"MSHTML 6.00.2900.3157" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>You can download the entire SDK or =
runtime from=20
here: <A=20
href=3D" http://www.eclipse.org/modeling/mdt/downloads/?project=3Duml 2">ht=
tp://www.eclipse.org/modeling/mdt/downloads/?project=3Duml2</A></FONT></D=
IV>
<DIV><FONT face=3DArial size=3D2>The prerequisites are also =
listed. =20
Downloading the SDK for example would enable the menus you are looking=20
for.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Or you can selectively choose the =
source code you=20
want from cvs.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>- James.</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:frc2st$va0$1@build.eclipse.org">news:frc2st$va0$1@build.ecli=
pse.org</A>...</DIV>Rasha,<BR>
<BLOCKQUOTE><A=20
href=3D"news://news.eclipse.org/eclipse.modeling.mdt.uml2">news://news.ec=
lipse.org/eclipse.modeling.mdt.uml2</A><BR></BLOCKQUOTE><BR ><BR>rasha=20
wrote:=20
<BLOCKQUOTE =
cite=3Dmid:a966c9a27f5468dbedf42deca65a44c4$1@www.eclipse.org=20
type=3D"cite">Thanks Ed and James for your help. Ed, could you please =
send to=20
me the contact info for the UML newsgroup, I couldn�t see it =
in the �to�=20
list. <BR><BR>James, the problem that I couldn�t find the =
�UML Editor�. I=20
have the features UML2Examples and UML2ExamplesSource plugins. I =
have the=20
SampleEcoreEdit but not the UML Edit. If you could know what I =
missed to=20
install as prerequisites for UML, It�ll be highly =
appreciated.=20
<BR><BR>Cheers, <BR>Rasha=20
<BR><BR><BR></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML >
------=_NextPart_000_007B_01C885BE.81A00ED0--
Re: Convert a UML file to Ecore file [message #252582 is a reply to message #252520] |
Thu, 27 March 2008 11:25  |
Originally posted by: Kenn.Hussey.embarcadero.com
Note that the action James is referring to is only an example... If the EMF
model wizard is used instead, and UML chosen as a source type, I believe you
should be able to convert multiple UML packages to Ecore at once...
Kenn
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:fseh2l$s11$2@build.eclipse.org...
> Hi Rasha,
> Unfortunately I believe you can only select one at a time.
> - James.
> "Rasha" <rtawhid@connect.carleton.ca> wrote in message
> news:6176741e023e45504b67aad1e704e578$1@www.eclipse.org...
>> Hi James,
>> Thanks so much for your help. I have one more question. It works fine
>> when I have only one package in my file. However when the file contains
>> more that one package for example another package for a profile, I
>> couldn't select more than one root model element.
>> Is there is any way to select more than one root model element?
>> Any help is greatly appreciated,
>> Rasha
FUDForum. Page generated in 0.09470 seconds
