Home » Eclipse Projects » Remote Application Platform (RAP) » Close Workbench
Close Workbench [message #24729] Wed, 16 May 2007 07:37 Go to next message
Hello all,
What is the best way to close the application ? or dispose http session ?
I'm tryed with: "PlatformUI.getWorkbench().close();", but It isn't
implemented yet, Is there any alternatives/workarround ?
Thanks in advance.
Roberto.
Re: Close Workbench [message #25268 is a reply to message #24729] Thu, 17 May 2007 12:56 Go to previous messageGo to next message
Hi Roberto,
here is a limited workaround that closes the workbench window and then
reaches down to w4t and attaches a PhaseListener that invalidates the
session after the current request was processed.
Thus You will end up with an empty client document just showing the
background image.
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShel l().close();
W4TContext.getLifeCycle().addPhaseListener( new PhaseListener() {
private static final long serialVersionUID = 1L;
public void beforePhase( final PhaseEvent event ) {
// do nothing
public void afterPhase( final PhaseEvent event ) {
W4TContext.getLifeCycle().removePhaseListener( this );
ContextProvider.getSession().invalidate();
public PhaseId getPhaseId() {
return PhaseId.RENDER;
Hope that helps
Rüdiger
Roberto Sá‡nchez wrote:
> Hello all,
> Thanks in advance.
> Roberto.
Re: Close Workbench [message #25350 is a reply to message #25268] Thu, 17 May 2007 14:17 Go to previous messageGo to next message
Perfect !! It's exactly what I looking for.
Thank you very much.
Regards.
Roberto.
Ruediger Herrmmann escribió:
> Hi Roberto,
> background image.
> // do nothing
> Hope that helps
> Rüdiger
>> Hello all,
>> Thanks in advance.
>> Roberto.
Re: Close Workbench [message #30300 is a reply to message #25268] Fri, 01 June 2007 09:48 Go to previous messageGo to next message
Originally posted by: benedikt.arnold.beyondsoft.de
Hi!
If I call
I get the following exception:
01.06.2007 15:45:52 org.mortbay.jetty.servlet.ServletHandler handle
SCHWERWIEGEND:
/rap?nocache=1180705552042&w2.activeControl=w10&org. eclipse.swt.events.widgetSelected=w13&w13.bounds.x=null& amp;w13.bounds.y=null&w13.bounds.width=auto&w13.boun ds.height=null&w1.focusControl=w11&uiRoot=w1&req uestCounter=0:
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1475)
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:603)
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:579)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:696)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:694)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:732)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:67 8)
at org.eclipse.swt.events.ShellEvent.dispatchToObserver(ShellEv ent.java:39)
at com.w4t.event.Event.processEvent(Event.java:45)
at org.eclipse.swt.events.TypedEvent.processEvent(TypedEvent.ja va:76)
at org.eclipse.swt.widgets.Shell.close(Shell.java:606)
de.beyondsoft.voipconf.web.ui.VoIPConfActionBarAdvisor$1.run (VoIPConfActionBarAdvisor.java:45)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:495 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:526)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:471)
org.eclipse.jface.action.ActionContributionItem$4.handleEven t(ActionContributionItem.java:424)
org.eclipse.swt.internal.widgets.UntypedEventAdapter.dispatc hEvent(UntypedEventAdapter.java:244)
org.eclipse.swt.internal.widgets.UntypedEventAdapter.widgetS elected(UntypedEventAdapter.java:72)
org.eclipse.swt.events.SelectionEvent.dispatchToObserver(Sel ectionEvent.java:116)
at org.eclipse.swt.events.TypedEvent.processEventClass(TypedEve nt.java:117)
org.eclipse.swt.events.TypedEvent.processScheduledEvents(Typ edEvent.java:57)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.proce ssAction(DisplayLCA.java:231)
org.eclipse.swt.internal.lifecycle.ProcessAction.execute(Pro cessAction.java:27)
org.eclipse.swt.internal.lifecycle.RWTLifeCycle.execute(RWTL ifeCycle.java:78)
at com.w4t.engine.W4TModel$ServiceAdapter.execute(W4TModel.java :47)
com.w4t.engine.service.FormRequestServiceHandler.service(For mRequestServiceHandler.java:65)
com.w4t.engine.service.ServiceManager$HandlerDispatcher.serv ice(ServiceManager.java:104)
at com.w4t.engine.W4TDelegate.doPost(W4TDelegate.java:75)
org.eclipse.ui.internal.servlet.RequestHandler.service(Reque stHandler.java:41)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:109)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:280)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
at org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
"Ruediger Herrmmann" <ruediger.herrmann@gmx.de> schrieb im Newsbeitrag
news:f2i1h4$k33$1@build.eclipse.org...
> Hi Roberto,
> background image.
> // do nothing
> Hope that helps
> R
Re: Close Workbench [message #30336 is a reply to message #30300] Fri, 01 June 2007 11:22 Go to previous messageGo to next message
Hi Benedikt, now I have the same problem, but when I tryed the first
time this worked fine.
Benedikt Arnold escribió:
> Hi!
> If I call
> SCHWERWIEGEND:
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> Hi Roberto,
>> background image.
>> // do nothing
>> Hope that helps
>> Rüdiger
>>> Hello all,
>>> Thanks in advance.
>>> Roberto.
Re: Close Workbench [message #30372 is a reply to message #30336] Fri, 01 June 2007 11:25 Go to previous message
this has to do with the switch to the RCP 3.3 codebase. Be patient, I'll
care for this the next days. If you want, just file a bug against the
Workbench component.
Greets
Benny
>> Hi!
>> If I call
>> SCHWERWIEGEND:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> Hi Roberto,
>>> then reaches down to w4t and attaches a PhaseListener that
>>> invalidates the session after the current request was processed.
>>> background image.
>>> // do nothing
>>> Hope that helps
>>> Rüdiger
>>>> Hello all,
>>>> session ?
>>>> Thanks in advance.
>>>> Roberto.
Previous Topic:Printing View
Next Topic:Opening a PDF, HTML, or other document in a new browser window
Current Time: Thu Nov 06 19:40:13 EST 2025
Powered by FUDForum. Page generated in 0.03794 seconds
