| Close Workbench [message #24729] |
Wed, 16 May 2007 07:37  |
Hello all,
What is the best way to close the application ? or dispose http session ?
I'm tryed with: "PlatformUI.getWorkbench().close();", but It isn't
implemented yet, Is there any alternatives/workarround ?
Thanks in advance.
Roberto.
| Re: Close Workbench [message #30372 is a reply to message #30336] |
Fri, 01 June 2007 11:25  |
this has to do with the switch to the RCP 3.3 codebase. Be patient, I'll
care for this the next days. If you want, just file a bug against the
Workbench component.
Greets
Benny
Roberto Sánchez wrote:
> Hi Benedikt, now I have the same problem, but when I tryed the first
> time this worked fine.
> Benedikt Arnold escribió:
>> Hi!
>> If I call
>> PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShel l().close();
>> I get the following exception:
>> 01.06.2007 15:45:52 org.mortbay.jetty.servlet.ServletHandler handle
>> SCHWERWIEGEND:
>> /rap?nocache=1180705552042&w2.activeControl=w10&org. eclipse.swt.events.widgetSelected=w13&w13.bounds.x=null& amp;w13.bounds.y=null&w13.bounds.width=auto&w13.boun ds.height=null&w1.focusControl=w11&uiRoot=w1&req uestCounter=0:
>> java.lang.NullPointerException
>> at
>> org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1475)
>> at
>> org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:603)
>> at
>> org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:579)
>> at
>> org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:696)
>> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
>> at
>> org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:694)
>> at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:732)
>> at org.eclipse.jface.window.Window$3.shellClosed(Window.java:67 8)
>> at
>> org.eclipse.swt.events.ShellEvent.dispatchToObserver(ShellEv ent.java:39)
>> at com.w4t.event.Event.processEvent(Event.java:45)
>> at org.eclipse.swt.events.TypedEvent.processEvent(TypedEvent.ja va:76)
>> at org.eclipse.swt.widgets.Shell.close(Shell.java:606)
>> at
>> de.beyondsoft.voipconf.web.ui.VoIPConfActionBarAdvisor$1.run (VoIPConfActionBarAdvisor.java:45)
>> at org.eclipse.jface.action.Action.runWithEvent(Action.java:495 )
>> at
>> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:526)
>> at
>> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:471)
>> at
>> org.eclipse.jface.action.ActionContributionItem$4.handleEven t(ActionContributionItem.java:424)
>> at
>> org.eclipse.swt.internal.widgets.UntypedEventAdapter.dispatc hEvent(UntypedEventAdapter.java:244)
>> at
>> org.eclipse.swt.internal.widgets.UntypedEventAdapter.widgetS elected(UntypedEventAdapter.java:72)
>> at
>> org.eclipse.swt.events.SelectionEvent.dispatchToObserver(Sel ectionEvent.java:116)
>> at
>> org.eclipse.swt.events.TypedEvent.processEventClass(TypedEve nt.java:117)
>> at
>> org.eclipse.swt.events.TypedEvent.processScheduledEvents(Typ edEvent.java:57)
>> at
>> org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.proce ssAction(DisplayLCA.java:231)
>> at
>> org.eclipse.swt.internal.lifecycle.ProcessAction.execute(Pro cessAction.java:27)
>> at
>> org.eclipse.swt.internal.lifecycle.RWTLifeCycle.execute(RWTL ifeCycle.java:78)
>> at com.w4t.engine.W4TModel$ServiceAdapter.execute(W4TModel.java :47)
>> at
>> com.w4t.engine.service.FormRequestServiceHandler.service(For mRequestServiceHandler.java:65)
>> at
>> com.w4t.engine.service.ServiceManager$HandlerDispatcher.serv ice(ServiceManager.java:104)
>> at com.w4t.engine.W4TDelegate.doPost(W4TDelegate.java:75)
>> at
>> org.eclipse.ui.internal.servlet.RequestHandler.service(Reque stHandler.java:41)
>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
>> at
>> org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180)
>> at
>> org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
>> at
>> org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:109)
>> at
>> org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
>> at
>> org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:280)
>> at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
>> at
>> org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
>> at
>> org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
>> at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
>> at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
>> at org.mortbay.http.HttpServer.service(HttpServer.java:909)
>> at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
>> at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
>> at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
>> at
>> org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
>> at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
>> at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
>> "Ruediger Herrmmann" <ruediger.herrmann@gmx.de> schrieb im Newsbeitrag
>> news:f2i1h4$k33$1@build.eclipse.org...
>>> Hi Roberto,
>>> here is a limited workaround that closes the workbench window and
>>> then reaches down to w4t and attaches a PhaseListener that
>>> invalidates the session after the current request was processed.
>>> Thus You will end up with an empty client document just showing the
>>> background image.
>>> W4TContext.getLifeCycle().addPhaseListener( new PhaseListener() {
>>> private static final long serialVersionUID = 1L;
>>> public void beforePhase( final PhaseEvent event ) {
>>> // do nothing
>>> public void afterPhase( final PhaseEvent event ) {
>>> W4TContext.getLifeCycle().removePhaseListener( this );
>>> ContextProvider.getSession().invalidate();
>>> public PhaseId getPhaseId() {
>>> return PhaseId.RENDER;
>>> Hope that helps
>>> Rüdiger
>>> Roberto Sá‡nchez wrote:
>>>> Hello all,
>>>> session ?
>>>> Thanks in advance.
>>>> Roberto.
FUDForum. Page generated in 0.03609 seconds
