Home » Eclipse Projects » Eclipse Platform » Failed startup due to missing Intro Page resources in RCP M9
Failed startup due to missing Intro Page resources in RCP M9 [message #251437] Thu, 10 June 2004 09:50 Go to next message
I'm running a RCP app with the following plugins:
org.eclipse.core.expressions
org.eclipse.core.resources
org.eclipse.core.runtime
org.eclipse.core.runtime.compatibility
org.eclipse.help
org.eclipse.jface
org.eclipse.osgi
org.eclipse.osgi.services
org.eclipse.platform
org.eclipse.swt
org.eclipse.swt.win32
org.eclipse.ui
org.eclipse.ui.cheatsheets
org.eclipse.ui.forms
org.eclipse.ui.intro
org.eclipse.ui.workbench
org.eclipse.update.configurator
(org.eclipse.ui.cheatsheets, org.eclipse.ui.forms, org.eclipse.ui.intro
were added by Eclipse from the "Add Required Plug-ins" button)
This works fine when I launch from Eclipse debug. However, when I package
and launch as a standalone RCP, I get the exception below. Apparently,
it's not finding an image for the intro page (which I could do without).
What am I missing or how do I turn off the intro page?
Stephen
org.eclipse.ui.internal.IntroAction.getImageDescriptor(Intro Action.java:77)
org.eclipse.jface.action.ActionContributionItem.updateImages (ActionContributionItem.java:1278)
org.eclipse.jface.action.ActionContributionItem.update(Actio nContributionItem.java:1152)
org.eclipse.jface.action.ActionContributionItem.fill(ActionC ontributionItem.java:633)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :603)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :525)
at org.eclipse.jface.action.MenuManager.fill(MenuManager.java:2 33)
org.eclipse.jface.action.MenuManager.createMenuBar(MenuManag er.java:159)
org.eclipse.jface.action.MenuManager.createMenuBar(MenuManag er.java:175)
org.eclipse.ui.internal.WorkbenchWindow.createDefaultContent s(WorkbenchWindow.java:690)
org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefa ultContents(WorkbenchWindowConfigurer.java:535)
org.eclipse.ui.application.WorkbenchAdvisor.createWindowCont ents(WorkbenchAdvisor.java:637)
org.eclipse.ui.internal.WorkbenchWindow.createContents(Workb enchWindow.java:674)
at org.eclipse.jface.window.Window.create(Window.java:348)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:985)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:174)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:658)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:817)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1311)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:253)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
com.lehman.emx.project.fxstack.application.Application.run(A pplication.java:14)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:307)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:256)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
Re: Failed startup due to missing Intro Page resources in RCP M9 [message #251442 is a reply to message #251437] Thu, 10 June 2004 10:04 Go to previous messageGo to next message
You probably don't need this plugin and this is where the intro is
specified. Just remove it.
Peter
Re: Failed startup due to missing Intro Page resources in RCP M9 [message #251446 is a reply to message #251442] Thu, 10 June 2004 10:15 Go to previous messageGo to next message
I've tried removing the following plugins:
I get the same exception. Judging by the exception, it seems to be
hardcoded that it tries to load a default intro page on first time
startup. While it would be best to be able to bypass the intro page, I
could live with it for now if I knew where the resource for the
IntroAction lived.
-Stephen
> Peter
Re: Failed startup due to missing Intro Page resources in RCP M9 [message #251473 is a reply to message #251446] Thu, 10 June 2004 10:40 Go to previous messageGo to next message
Ahh... This was my fault. I was adding the ActionFactory.INTRO action to
the Help menu but wasn't specifying any intro in my application.
Re: Failed startup due to missing Intro Page resources in RCP M9 [message #251477 is a reply to message #251446] Thu, 10 June 2004 10:57 Go to previous message
Did you clear your configuration and run against a new workspace if you
have one. Assuming of course that is where the information it is looking
for is.
I have an RCP application and there is no intro page at all and I don't
reference it. My plugin list is similar to yours except I have the
update.core plugins and the workbench.compatibility plugins. But not
core.expressions and core.resources.
Peter
> IntroAction lived.
> -Stephen
>>Peter
Previous Topic:Open Workspace problem in 3.0M9
Next Topic:Set selection programmatically
Current Time: Mon Jul 21 23:52:36 EDT 2025
Powered by FUDForum. Page generated in 0.04319 seconds
