Home » Language IDEs » Java Development Tools (JDT) » Open th JavaProjectWizard out of an other Wizard
Open th JavaProjectWizard out of an other Wizard [message #251404] Thu, 14 February 2008 04:49 Go to next message
Originally posted by: dennis.dumke.novastor.com
Hello everybody,
I try to open the JavaProjectWizard out of my own wizard. But always if I call the performFinish method from the JavaProjectWizard i get an exception and the method exit without a value. Could someone help me?
My trying:
In try to wrap the JavaProjectWizard and init it in addPages(). And for using the JavaPrjectWizard I get the pointer from the first and second JavaProjectWizard page and add them into my wizard. After all (when the user calls finish by the JavaProjectWizard) I call the performFinish method form the javaProjectWizard. The project is created fine but the wizard doesn’t end .
public class QuickJavaProjectWizard extends Wizard implements INewWizard {
protected JavaProjectWizardFirstPage javafirstpage;
private JavaProjectWizardSecondPage javasecondpage;
private JavaProjectWizard javawizard;
public boolean performFinish() {
// TODO Auto-generated method stub
if(getContainer().getCurrentPage() != this.mainpage){
boolean tmp = this.javawizard.performFinish();
return tmp;
if(getContainer().getCurrentPage().equals(this.mainpage)){
JavaProjectUtils utils = new JavaProjectUtils();
utils.createProject(this.model.projectname, this.model.getWorkspace());
return true;
return false;
public void addPages() {
this.mainpage = new QuickJavaProjectWizardMainPage("SelectionPage");
this.mainpage.setTitle("Quick Java Project Wizard");
this.mainpage.setDescription("Wizard for fast Java Project creation");
addPage(this.mainpage);
this.javawizard = new JavaProjectWizard();
this.javawizard.addPages();
IWizardPage[] javapages = this.javawizard.getPages();
this.javafirstpage = (JavaProjectWizardFirstPage)javapages[0];
this.javasecondpage = (JavaProjectWizardSecondPage)javapages[1];
addPage(this.javafirstpage);
addPage(this.javasecondpage);
Dennis Dumke <dennis.dumke@novastor.com>
Re: Open th JavaProjectWizard out of an other Wizard [message #251625 is a reply to message #251404] Mon, 25 February 2008 06:00 Go to previous message
Note that all these clases are internal. Since 3.4
NewJavaProjectWizardPageOne and NewJavaProjectWizardPageTwo are public
and it should be simple to recreate the new Java project wizard. There's
also an example in org.eclipse.jdt.ui.tests/examples
If not, file a bug report.
Martin
Dennis Dumke wrote:
> Hello everybody,
> My trying:
> @Override
> return tmp;
> return true;
> return false;
> @Override
Previous Topic:How to translate a java stack trace into an other language stack trace ?
Next Topic:[refactoring] questions before implementing my own refactor
Current Time: Sat Nov 08 13:20:27 EST 2025
Powered by FUDForum. Page generated in 0.03465 seconds
