Home » Archived » BIRT » Can't startup the OSGI framework
Can't startup the OSGI framework [message #251403] Tue, 07 August 2007 02:20 Go to next message
Originally posted by: sjaheer.gmail.com
I am trying to run a report from the stand alone java class, and am
getting the following exceptions.
debug : 1
debug : 2
debug : 3
debug : 4
debug : 5
debug : 6
org.eclipse.birt.core.exception.BirtException: Can't startup the OSGI
framework
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:89)
org.eclipse.birt.report.engine.api.ReportEngine.<init>(ReportEngine.java:54)
at com.alshaya.ares.em.report.FireReport1.<init>(FireReport1.java:76)
at com.alshaya.ares.em.report.FireReport1.main(FireReport1.java :159)
Caused by: org.eclipse.birt.core.exception.BirtException: Could not find
the Framework - {0}
org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OS GILauncher.java:95)
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:77)
... 3 more
Can't load the report engine
debug : 7
debug : 8
Exception in thread "main" java.lang.NullPointerException
org.eclipse.birt.report.engine.api.ReportEngine.openReportDe sign(ReportEngine.java:121)
following is my java class
import java.util.Calendar;
import java.util.GregorianCalendar;
import java.util.HashMap;
import java.util.logging.Level;
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.core.framework.IPlatformContext;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.core.framework.PlatformFileContext;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLCompleteImageHandler;
import org.eclipse.birt.report.engine.api.HTMLEmitterConfig;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IGetParameterDefinitionTa sk;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.PDFRenderContext;
import org.eclipse.birt.report.engine.api.RenderOptionBase;
import org.eclipse.birt.report.engine.api.ReportEngine;
public class FireReport1
public FireReport1()
// Create an EngineConfig object.
EngineConfig config = new EngineConfig( );
System.out.println("debug : 1");
// Set up the path to your engine home directory.
config.setEngineHome(
"D:/birtruntime/birt-runtime-2_2_0/ReportEngine" );
System.out.println("debug : 2");
try
Platform.startup(config);
catch (BirtException e2)
// TODO Auto-generated catch block
System.out.println("here 1: "+e2.getMessage());
System.out.println("debug : 3");
// Explicitly set up the stand-alone application
IPlatformContext context = new PlatformFileContext( );
config.setEngineContext( context );
System.out.println("debug : 4");
// set log config using ( null, Level ) if you do not want a
log file
//config.setLogConfig(path+"logfiles", Level.FINE);
// Set up writing images or charts embedded in HTML output.
HTMLCompleteImageHandler imageHandler = new
HTMLCompleteImageHandler( );
HTMLEmitterConfig hc = new HTMLEmitterConfig( );
hc.setImageHandler( imageHandler );
System.out.println("debug : 5");
config.setEmitterConfiguration(
RenderOptionBase.OUTPUT_FORMAT_HTML, hc );
System.out.println("debug : 6");
// Create the engine.
ReportEngine engine = new ReportEngine( config );
System.out.println("debug : 7");
String designName = "D:/BirtJavaReport/hideRows.rptdesign";
IReportRunnable runnable = null;
System.out.println("debug : 8");
try
runnable = engine.openReportDesign( designName );
catch ( EngineException e )
System.err.println( "Design " + designName + " not found!" );
engine.shutdown( );
System.exit( -1 );
System.out.println("debug : 9");
// Get the value of a simple property.
String author = ( String ) runnable.getProperty(
IReportRunnable.AUTHOR );
System.out.println("debug : 10");
/* Configuring properties on an IRunAndRenderTask object */
// Create a run and render task object.
IRunAndRenderTask task = engine.createRunAndRenderTask(
runnable );
System.out.println("debug : 11");
HTMLRenderOption options = new HTMLRenderOption( );
String output = "D:/BirtJavaReport/html/hideRows.html";
options.setOutputFileName( "hideRows.html" );
System.out.println("debug : 12");
// Apply the rendering options to the task.
task.setRenderOption( options );
System.out.println("debug : 13");
// Instantiate an HTML rendering context object and
// set the name of the directory for images.
HTMLRenderContext renderContext = new HTMLRenderContext( );
renderContext.setImageDirectory("path+image");
System.out.println("debug : 14");
// Apply the rendering context to the task.
HashMap appContext = new HashMap( );
appContext.put(
EngineConstants.APPCONTEXT_HTML_RENDER_CONTEXT, renderContext );
System.out.println("debug : 15");
task.setAppContext( appContext );
System.out.println("debug : 16");
/* Generating a report from a report design or a report
document */
try
task.run( );
System.out.println( "Created Report " + output);
catch ( EngineException e1 )
System.err.println( "Report " + output + " run failed." );
System.err.println("here 2: "+ e1.toString( ) );
System.out.println("debug : 17");
engine.shutdown( );
System.out.println("debug : end");
public static void main(String args[])
new FireReport1();
can anybody pl help to run the report from the stand alone java class
Thanks for all in advance
java.lang.NullPointerException while running the report from standalonjava class [message #251416 is a reply to message #251403] Tue, 07 August 2007 04:58 Go to previous messageGo to next message
i just modified my java code and moved one step ahead but still am getting
following is my java classs code
at com.alshaya.ares.em.report.TestClass.<init>(TestClass.java:44)
at com.alshaya.ares.em.report.TestClass.main(TestClass.java:81)
at com.alshaya.ares.em.report.TestClass.<init>(TestClass.java:54)
public FireReport()
try
config.setEngineHome( "D:/birtruntime/birt-runtime-2_2_0/ReportEngine" );
// set log config using ( null, Level ) if you do not want a log file
config.setLogConfig("D:/BirtJavaReport/logfiles", Level.FINE);
try
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
IReportEngine engine = null;
try
engine = factory.createReportEngine( config );
engine.changeLogLevel( Level.WARNING );
catch(Exception exep)
System.out.println("here 2 :");
exep.printStackTrace();
//Open a report design - use design to modify design, retrieve embedded
images etc.
IReportRunnable design =
engine.openReportDesign("D:/BirtJavaReport/hideRows.rptdesign ");
//Create task to run the report and render the report
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
//Set rendering options - such as file or stream output,
//output format, whether it is embeddable, etc
HTMLRenderOption options = new HTMLRenderOption();
//options.setOutputStream(System.out);
options.setOutputFileName("D:/BirtJavaReport/html/hideRows.html ");
options.setOutputFormat("html");
task.setRenderOption(options);
task.run();
engine.destroy();
Platform.shutdown();
System.out.println("Finished");
catch(Exception exe)
System.out.println("Here 3 : ");
exe.printStackTrace();
new FireReport();
Re: java.lang.NullPointerException while running the report from standalonjava class [message #251507 is a reply to message #251416] Tue, 07 August 2007 12:12 Go to previous message
Shaik,
What line are you getting the exception on?
Jason
shaik wrote:
> public FireReport()
> try
> file
> try
> } catch (BirtException e2) {
> try
> embedded images etc. IReportRunnable design =
> task.run();
> engine.destroy();
> System.out.println("Finished"); }
> new FireReport();
Previous Topic:How to display the contents of the previous row in the report?
Next Topic:BIRT Integration with PDE...
Current Time: Sat Aug 30 21:15:58 EDT 2025
Powered by FUDForum. Page generated in 0.03646 seconds
