Home » Archived » Riena » Object transactions: register vs. registerNew
Object transactions: register vs. registerNew [message #24726] Mon, 20 April 2009 01:28 Go to next message
I wonder what the exact difference between IObjectTransaction#register() and
#registerNew is? Can anyone give me a hint?
Thanks and greetz
Carsten
Re: Object transactions: register vs. registerNew [message #24764 is a reply to message #24726] Tue, 21 April 2009 05:59 Go to previous messageGo to next message
Hi Carsten,
As far as I know the difference is:
- with register() an object is registered that should not be tracked as
a new object
- while registerNew() registers a new object which should be tracked
Tschüß,
Stefan
Carsten Spieker wrote:
> Thanks and greetz
> Carsten
Re: Object transactions: register vs. registerNew [message #24800 is a reply to message #24764] Tue, 21 April 2009 13:46 Go to previous message
Like Stefan said,
the difference is the state that the registered object gets. The object transaction keeps a state if the object was
brought in as "new" object or whether it was instantiate new but already existed in your persistentant store.
So later when you extract the Changes then you get the information whether that was an object that was new or existing
in the first place.
hope that helps
christian
Stefan Liebig schrieb:
> Hi Carsten,
> a new object
> Tschüß,
> Stefan
>> IObjectTransaction#register() and #registerNew is? Can anyone give me
>> a hint?
>> Thanks and greetz
>> Carsten
Re: Object transactions: register vs. registerNew [message #581922 is a reply to message #24726] Tue, 21 April 2009 05:59 Go to previous message
Hi Carsten,
a new object
Tschüß,
Stefan
> Thanks and greetz
> Carsten
Re: Object transactions: register vs. registerNew [message #581943 is a reply to message #24764] Tue, 21 April 2009 13:46 Go to previous message
Like Stefan said,
in the first place.
hope that helps
christian
> Hi Carsten,
> a new object
> Tschüß,
> Stefan
>> a hint?
>> Thanks and greetz
>> Carsten
Previous Topic:Object transactions: register vs. registerNew
Next Topic:Deploying Riena applications
Current Time: Mon Sep 01 15:33:13 EDT 2025
Powered by FUDForum. Page generated in 0.04236 seconds
