Home » Language IDEs » Java Development Tools (JDT) » Handling the configuration of a classpath container
| Handling the configuration of a classpath container [message #251334] |
Mon, 11 February 2008 11:04  |
Originally posted by: nicolas.lalevee.anyware-tech.com
I am having trouble about supporting the configuration of a classpath
container. I asked some help on eclipse.platform with no success, I didn't
saw that there were a JDT newsgroup.
So here is my first message :
The plugin I work on is IvyDE: http://ant.apache.org/ivy/ivyde
I am hitting is an issue when a project is imported, with a .classpath
referencing the IvyDE container, and with
a .settings/org.apache.ivyde.eclipse.prefs containing the Ivy
configuration. But the project preferences attached to IvyDE is not loaded
when the classpath container is created. So the classpath container assume
it should use the default preferences, which can make a lot of errors if
the project preferences are absolutely needed. After that, if I manually
trigger the resolve on the IvyClassPathContainer (via an action), the
preferences are correctly loaded, and everything works fine. In fact the
refresh thread runs too late.
In fact I have exactly the same use case as described here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=139911
I have tried to make a job scheduled by the
IvyClasspathContainerInitializer, made the job a priority BUILD, it still
runs before the refresh job.
The refresh job not having any scheduling rule, I cannot make them conflit.
Is there a way to schedule that resolve job after the refresh one ?
Or should I force the refresh of IvyDE's settings file ?
Or should I store preferences even if there is no preference to store ? So
the container would wait to load until there is actually some preferences
(via listeners).
And a second message
I have looked how the JDT does, how the build tasks manage the preference
loading against the refresh job.
In fact in Project#open, there is:
worspace.beginOperation
startup => trigger the OPEN event which create the classpath containers
refresh
workspace.endOperation => trigger the build
So effectively, the build can launch the preferences safely. Should the
classpath container be populated by a build job ?
Then discussing on a IvyDE issue
(https://issues.apache.org/jira/browse/IVYDE-70)
Then rethinking about how the JDT works, it finally seems that having
preferences to control a class path container is wrong. And in fact IvyDE
has two configuration panes: the one which control the conf to resolve, and
the one which control the ivysettings url, the jar, source, javadocs types,
etc...
Then I browsed the JDT classes and I have found the IClasspathAttribute,
which should be used to store extra configuration about the class path
entry. So it seems that my issues will be resolved properly if I merge the
two confiuration panes, and if we make the current preferences stored as
classpath extra attributes (which will finally get stored into
the .classpath).
After a first attempt, I sucessfully generated a .classpath with:
<classpathentry kind="con"
path=" org.apache.ivyde.eclipse.cpcontainer.IVYDE_CONTAINER/ivy.xml /* ">
<attributes>
<attribute name="ivySettingsPath"
value=" file:/home/nicolasl/dev/......../tools/1.0/ivyconf-eclipse.x ml "/>
</attributes>
</classpathentry>
But then I started playing with the IvydeContainerPage (implementing
IClasspathContainerPage) which create the IClasspathEntry. So I made it put
some extra attributes in the classpathentry. But the JDT doesn't care and
ignore them...
So using IClasspathAttribute for classpath containers is a bad idea ?
And all the configuration of the classpath container should be kept into the
container's path ?
As the path would be a concatenation of configuration entries, what happend
is one of the configuration is actually a path ?
Thanks in advance for taking time to read my message.
Nicolas
| Re: Handling the configuration of a classpath container [message #251360 is a reply to message #251334] |
Tue, 12 February 2008 15:09   |
Just an idea :
you can get a reference of the refresh job tahnks to IJobManager static
method from your job instance. If having chance to get a reference on
refresh job ou can then add an IJobChangeListener on it, implementing
the done method.
If you cant access that reference, it is just too bad ...
hope this helps !
Anyway, hi to Toulouse Anyware's/Joost crew from me !
Nicolas Lalevée a écrit :
> (via listeners).
> refresh
> etc...
> the .classpath).
> <attributes>
> </attributes>
> </classpathentry>
> ignore them...
> container's path ?
> Nicolas
| Re: Handling the configuration of a classpath container [message #251440 is a reply to message #251360] |
Fri, 15 February 2008 08:36  |
lucas bigeardel wrote:
> Just an idea :
> the done method.
> hope this helps !
Hi Lucas ! Good to read you here ! :)
Thanks for the idea, I will look to it.
cheers,
Nicolas
>> didn't saw that there were a JDT newsgroup.
>> loaded when the classpath container is created. So the classpath
>> container assume it should use the default preferences, which can make a
>> lot of errors if the project preferences are absolutely needed. After
>> that, if I manually trigger the resolve on the IvyClassPathContainer (via
>> an action), the preferences are correctly loaded, and everything works
>> fine. In fact the refresh thread runs too late.
>> conflit.
>> So the container would wait to load until there is actually some
>> preferences (via listeners).
>> refresh
>> and the one which control the ivysettings url, the jar, source, javadocs
>> types, etc...
>> the two confiuration panes, and if we make the current preferences stored
>> as classpath extra attributes (which will finally get stored into
>> the .classpath).
>> <attributes>
>> </attributes>
>> </classpathentry>
>> put some extra attributes in the classpathentry. But the JDT doesn't care
>> and ignore them...
>> the container's path ?
>> happend is one of the configuration is actually a path ?
>> Nicolas
Current Time: Thu Nov 13 22:22:34 EST 2025
Powered by FUDForum. Page generated in 0.05209 seconds
