Home » Eclipse Projects » Eclipse Platform » [newbie] Getting the selected resource in a popup menu action
[newbie] Getting the selected resource in a popup menu action [message #251304] Wed, 09 June 2004 21:28 Go to next message
Originally posted by: kapland.uci.edu
It seems like every single pop-up menu action in the documentation always
creates a dialog box. But what I would like to do is do something with the
file that I just right-clicked on to make that pop-up menu show up in the
first place.
How do I do this? Is there a method called getSelectedResource() or
something? Thanks.
Re: [newbie] Getting the selected resource in a popup menu action [message #251452 is a reply to message #251304] Thu, 10 June 2004 10:27 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
If your action was contributed through the plugin.xml, then it must
implement IActionDelegate. If so, then it is told what was selected via
the setSelection method.
Thanks, Rich Kulp
Re: [newbie] Getting the selected resource in a popup menu action [message #251541 is a reply to message #251452] Thu, 10 June 2004 13:45 Go to previous messageGo to next message
I've checked the API and i see no existence of setSelection method in an
IActionDelegate
Would you mind being a little more detailed in how to do it? This is how i
currently do it:
package MenuSample.popup.actions;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.ui.IObjectActionDelegate;
import org.eclipse.ui.IWorkbenchPart;
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.core.resources.IResource;
public class NewAction implements IObjectActionDelegate {
private String title;
private IResource resource;
private IStructuredSelection sSelection;
private IWorkbenchPart part;
private IWorkbenchWindow window;
* Constructor for Action1.
public NewAction() {
super();
* @see IObjectActionDelegate#setActivePart(IAction, IWorkbenchPart)
public void setActivePart(IAction action, IWorkbenchPart targetPart) {
part = targetPart;
* @see IActionDelegate#run(IAction)
public void run(IAction action) {
sSelection = (IStructuredSelection)
part.getSite().getSelectionProvider().getSelection();
resource = (IResource) sSelection.getFirstElement();
title = resource.getName();
Shell shell = new Shell();
MessageDialog.openInformation(
shell,
"MenuSample Plug-in",
title);
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:ca9qle$bp5$2@eclipse.org...
> Thanks, Rich Kulp
Re: [newbie] Getting the selected resource in a popup menu action [message #251623 is a reply to message #251541] Thu, 10 June 2004 17:54 Go to previous message
It's called selectionChanged(Selection). It is called when the selection
has changed.
Thanks, Rich Kulp
Previous Topic:Sharing bookmarks/tasks?
Next Topic:[rc1] binary project w/linked content: no source available
Current Time: Fri Nov 07 18:25:36 EST 2025
Powered by FUDForum. Page generated in 0.03400 seconds
